shbazjinkens had originally linked to Dan’s workshop when commenting on the backyard aluminum foundry. Dan uses a lost foam technique for casting his parts: the foam burns out of the mold to be replaced by metal. To make the initial foam pieces he built this hot wire based foam cutting lathe (out of cast parts natch). Nice little specialized tool that you definitely wouldn’t find easily. Dan is also responsible for the hot air pencil we mentioned the other day. Needless to say, there is a lot of good stuff on his site so have a look around.
Last night someone sent in the site that slashdot linked to in this story: http://hardware.slashdot.org/hardware/05/07/13/1313232.shtml
I was excited to run it today till I realized we’ve pretty much beat this idea to death: http://www.hackaday.com/search/?q=projector
Oh well, someone would have just mentioned Lumenlab in the comments anyway.
There is a wealth of information available on metalworking, DIY metalworking tools, foundries, etc… at
http://www.lindsaybks.com/HomePage.html
