[SeBsZ] built this 16 dimmable lights controller based on his friend Christian N?g’s PC_DIMMER project. The PC_DIMMER project supports up to 128 individual lamps with 255 steps each. The controller boards feature an Atmel ATTiny2313 microcontroller that controls 8 lamps. Sebsz built two boards for his project and has status indicators mounted on the side of the box. Everything is driven by Christian’s free software through a serial connection. SeBsZ warns that this is a 230V@50Hz design and you will need to modify it if you intend to use it in the US.
Continue reading “Computer Controlled Multiple Light Dimmer”
