Master modder [Jani ‘Japala’ P?? latest hack is adding an LCD screen into a mouse. The LCD is from a Nokia 6610. It fits pretty well since the controller board isn’t any larger than the screen. The controller requires adding three more wires to the mouse. These are connected to a parallel port. The screen can only show about 1 frame per second, but that is fast enough for general statistics or showing photos. It’s a really clean build. A clever trick was using a piece of plastic from the blister pack to cover the screen since it was already the same shape as the mouse.
[thanks z]
