USB Alien DAC
[blip] let us know about this nice little project. The Alien DAC Project is basically a DIY USB sound card/interface. [Pictured is one built by cook on head-fi.org] It uses a TI PCM2702 at its core with some supporting chips for power regulation and virtual ground for the analog audio signal. It’s small and should do the job. If you’re really interesting in taking it to the next level, check out the DAC-3. It’s like the big mean older brother of the Alien DAC. That thing is rack mounted, has Optical, Coax and USB inputs.
[If you run across any more floating ads, let me know. They shouldn’t on the site, and we’re trying to take care of them.]
