I’m at the beach this week – finally on vacation. Thanks to DD-WRT, I’ve got a handy wireless repeater to keep the beach house covered with network access. [sprite_tm]’s doing his best to make my vacation easier. He built this knock activated automatic door opener for a friend who wanted easy access to some locked, but empty flat (think british apartment) rooms. He used an ATTINY with some fets to drive the stepper (you can find those in old dot matrix printers for free) and a small transistor amped mic circuit to pick up the knocks. Knock the right code, and you’ll get let right in.
17 thoughts on “Knock Response Automatic Door Opener”
Leave a Reply to pretoriousCancel reply
I remember seeing a similar commercial product. Everything was mounted within a door so it could not be tampered with. the “knock code” was so long and precise it used a small battery powered key to do the knocking.
this seems like a good candidate for using one of those piezo sensors glued to the door.
This would be awesome fun to hack, if some how indicates a mistake you could keep trying, well it would be very hard but none the less fun.
Port Knocking comes full circle!
I’m waiting for someone to make one that uses a webcam to detect shadow puppets through the peep hole as a access control method :P
Damn….. I just stumbled over this and thought Id submit it but it looks like I was beaten to it! oh well… it was a cool idea.
I’m working on (Read: About to start, anytime now :P) a similar setup, but it takes a picture with a webcam through the peephole of whoever knocked. An answering machine, but for your door.
Cool design might leeve you a bit open to break ins tho
Well, it looks unsafe, but it’s like the apartment entrydoor opener connected to your doorbell, if you won’t know it’s there, no one will brute-force knock you!
and because it’s a empty building, your neighbors won’t get tired from your knock-sequence, so they won’t give it a try someday..
nice hack!
very nice. maybe piezzo would be a bit more appropriate for mounting/gluing onto a dor.
I’d like to try this with a capacitance switch on a doorknob. Or weirder yet, a musical lock with a door embedded theramin.
Another interesting idea for this would be using a few hall-effect detectors set in several spots on the inside of the door. To open the door you just put a small neodym magnet close to where you know the detectors are, then the door pops open.
Would be nice to have one where you’d have to sing a song every time you want to get the door open.
(imagine a scene where you’d have to go to the toilet)
hi
asl plz please give me idea of haking a webside now plz ok
http://www.hackaday.com/category/cellphones-hacks/
Sounds fun but I’d prefer using a key any day.
I am starting my own blog too, your is really nice!
