[krazywhiteguy310] let me know about the announcement of the Pandora battery hack. It’ll cost you a Sony PSP battery to pull off the hack, but once you’re done, you can use it to jump start your bricked PSP to load up a memory imaged designed to unbrick the PSP. (I haven’t tested it, so I’m taking this on faith) Excellent news if you’ve bricked your PSP.
124 thoughts on “Pandora’s Battery (unbrick Your PSP)”
naaaa hey guys I wanna know why most most of you here want to downgrade the firmware?
as far as I know the latest firmware is will be the best… currently I upgrade my firmware from 3.90MM-3 to 5.00MM-3 firware and it was working fine I can play all the EBOOT games and it’s compatible to all previous firmware games as long as you’ll going to update the SEPLUGGINS of the PSP. I’ve got all this resources at http://www.pspiso.com go to games section and look for the account of HAKO everything regarding to the instructions of upgrading your firmware and using the pandoras battery is there. check it out and see it for your self…
as far as I know the latest firmware is will be the best… currently I upgrade my firmware from 3.90MM-3 to 5.00MM-3 firware and it was working fine I can play all the EBOOT games and it’s compatible to all previous firmware games as long as you’ll going to update the SEPLUGGINS of the PSP. I’ve got all this resources at http://www.pspiso.com go to games section and look for the account of HAKO everything regarding to the instructions of upgrading your firmware and using the pandoras battery are there. check it out and see it for your self…
ive seen an advert for a battery that can be used for pandora but has a switch that lets it be used as a normal battery how can this work
Sweet – thanks for the info.
I agree 5.00MM-3 firmware is the best at the moment! I’m waiting for the breaking news ” the latest psp version can be hacked!!” sounds impossible huh..
Pearce- Yes there is a battery that allows you to switch back and forth between Pandora mode and regular mode.
hi i’m new to all this i have read bits about how this is done i have a slim psp2003 v4.01. i have also bought a pandora battery i have a 1gb mem card and a 8gb mem card can someone please help on how i can start to play games of my memory card
thanks.
I’m a newbie, have a pandora battery and new 4gb memory card from dealextreme.com
Can someone recommend a specific site or email me instructions on what to do next.
wmchaffins@Yahoo.com
Thank you
hi. i have a older psp (fat one) with firmware 5.00. i have a magic memory stick with all the requird files on and a pandora battery. When i insert the pandora battery the power light shows theres a battery there but the screen wont come on at all, just stays black. Is there anyone who can help me?
great post! thanks man..
I have a question about running ISOs. I downgraded my psp to v1.5 bout a year and a half ago and haven’t really done much ever since. I have the Devhook 0.46 which allows me to switch between 2.71 and 1.5. I wanted to play homebrew games and it worked great for me so far. However now that I found out you can play ISO files, I can only get couple ISO files to run on it. I’ve been out of this for a while now and looks like everything has changed. I just downloaded Pandora Deluxe 3.0. Will running that program change anything for my psp? And what the heck is a Pandora’s battery. When I was downgrading mine I never had to worry about anything like that. Any help would be greatly appreciated. Thanks
I just went fron devhook 0.56 on a 1.50 OFW to 5.0 M33-4 CFW last weekend. I hadn’t fooled with it for a while, like you.
You need to go get Despertar del Cementerio version 8 and it helped me create a pandora battery and ramp up to 5.00 M33-4.
I might have gone to 3.71 M33-3 before I went to 5.00. I forget.
But one of the upgrades did TAKE OVER AN HOUR, so be patient, it really takes that long especially on a psp-1001.
how will i know if my psp is bricked?
and whats the difference with semi-brick and brick?
how to unbrick semi-brick psp or brick psp?
please reply..thanks!
Let me google that for you!
http://letmegooglethatforyou.com/?q=how+to+unbrick+semi-brick+psp+or+brick+psp
If you want a Pandora Battery for 16€ contact me!
We also have Memory Stick pro duo 8Gb (22€)
Senderweb@gmail.com
Ok, so i read your post and everything. The first thing someone needs to do before editing firmware and downgrading is purchasing a Pandora Battery and MMS if you haven’t gotten one already.
One site that I recommend is this: http://www.psppandora.net
I usually buy from there when I mod and hack for others, but that your choice if you want to get from them. It pretty cheap compared to everywhere else.
After buying, if you need help let me know.
Can we use a pandora’s battery to downgrade the latest PSP version 5.03?
Also is it a risky operation in general?
Thanks a bunch in advance for the replies.
aadit – Yes you can downgrade the 5.03 firmware as long as your PSP isn’t the 3000.
can i crack a PSP3000 which is version 5.02?
if i could, will it be risky?
Hi, i got a psp 1001 and i was updating to the latest firmwere its 500 something, its downloaded on my duo card, but power went out and my upload did not take! The psp is not got cfw just what sony gives you, i dont want cfw, can i use pandora batt with my duo with the upgrade from sony to unbrick my psp? ” my brick is were only green light is on for 30-60 sec no pic/no sound”
hi everybody, i have a problem with my psp, its brick, when i insert mmc and pandora battery all leds turn on (wireless,memory and power) after 15sec nothing happen please help me (sorry for my english)
How can I rehack my psp? My screen cracked and I had to replace it. It is not running like it used to. What can I do?
my psp will not work with the memory stick in it will only work when the memory stick is out even if the battery is out and it is running on ac adapter it will not work when you put the memory stick in it shuts down then will not come back on it will light up but then shut off right away please help
thank you
ray
without any of this this hack, what’s wrong with just leaving your psp-3004 alone and running Sony made games from that small CD?
my 3k is perfect the way it is and i can get so many used games on umd for $10 at the pawnshop i’ll never be able to play them all. new titles too.
and the 3k screen is so much better than the 2k. the colorspace mode is superior. the interlacing hype is a total lie.
yeah, just get a 3k and use it, it does enough things well.
Hello,
I have been trying to make my own memory stick for about 2 weeks and can not get to the custom firmware screen. I am to the point where I just want to buy one. Can anyone recommend a website?
I was looking as PandoraSales.com or Pandorabattery.net?
Thank for any advise. Just do not want to ripped off.
omg i got a new battery an its way diffrent then the last one i hacked the model number is missing but i got this BP- an you help me find out what it is thanks
u know what i hate this keybord lolol
well u know what pandora battery kit should be must for everyone…iam in love with my psp now..recently i installed custom firmware on my psp offical firmware when i bought pandora battery kit with 16 gig stick from http://www.pspoverhaul.com/ and now i am running all fricken games without umd shit…lot of homebrew tutorials are also there..
I just went in and opened the battery and cut a line
and fixed it with a pencil and some tape and it was good as new.
im wondering if anyone has the blue led pandora battery from http://www.wholesale-elite.com ? I got the battery into pandora mode but for some reason my PSP will not load the magic memory stick i made with Rain’s MMS Maker lite…any suggestions?
is pandora original battry working on psp 2004
I have a PSP3000 and it bricked itself, how can i unbrick it?
ive got a dagital pandora battery and created my own mmc. .
when i try them on, it doesn’t work. .the PSP’s screen is just blank. .
what am i doin wrong ?
HELLP PLZz !
Just wait, something should pop up like PRESS X TO INSTALL or something. I’m 11 and I sucessfully created a MMC (easy!) and pandoras (almost shorted it, thank god that most shorts fix themselves overnight) and I got 3.71 M33 to 5.00 M33-6 and it rocks
I have a psp (fat), it was running the official sony firmware 5.00, i decided to update it, during the update, the psp froze, and i took out the battery, now it won’t start, power indicator is on, but the screen just stays black. I dont know whats wrong, could somebody explain to me the procedure to fix it, and can i use the pandora battery+Magic mem to fix it, plz get back to me via email__-it’s Gurtej.s.gambhir@live.com
hi, i recently update my psp3000 with chicHen R2 and and gen A full but unfotunitly i meshe with flash0 and my psp didnot working what can i do plz help me. My big Brother gona kill me
HELP
hi i have firmware 3.80 is it still possible to downgrade? pls help
hi…… i buy yesterday psp 2004 system software 5.50 . now i dont understand what to do to play free games on it. but first of all i want to ask some question? what if you have system software version 5.50????
n what is pandora battery? i dont get it? what do you use of it?
what is Magic MS????? memory stick? can any one want to tell me plz?xxxxxx
add me . d3vil_to_3vil@live.com
where do u download the software?
hi ive got a fat with ver 6.00 and want psp youtube i know i need a costum firmware but whitch one and what is the point of the pandore and magic stuff thanks ben
will it just show files and i click on one? I tried hacking and it wouldnt let me. someone please help!!!!!!!!!!!!!!!!
Can anyone help me
I just tried to upgrade from 5.50 GenB to Gen C and by mistake used the second option, Now my psp is at 5.50 and wont read my iso’s when i clicked on the xgen to try it again it says file was corrupted. I am using a slim Ta-85.
Please help
I need help please.. I need a explanation and suggestion could anyone can help me on my problem on my psp 2000 Ta 088v3. yesterday i upgrade my system version 5.03 to GEN 5.50 GEN A and I bricked my psp. I read all guide to make pandora battery and using magic memory stick but before i do it could you explain to me. It is possible to unbrick my psp using this method?
i need a fulll explination on how to even open up my fat psp battery let alone how to do the mod plz can u send me the stuff i need to this email killkill1@hotmail.com thx
guys is the psp battery a memory to does it have the flash0 if i buy a new 1 is der a flash0 there for da psp?cause mine bricked
I brought a PSP-1000 from cousin. He did that pandora battery thingy crap. If I buy a regular un-modded battery will my PSP work regular again?
HI…I HAVE PSP 3004 OF VER 5.03 AND IT GOT BRICKED WHEN I TRIED TO CONVERT IT INTO VER 5.51 SO PLS TELL ME WAT TO DO
Hey, does this work on a PSP 3000??
fuck me, does no-one know how to use google anymore.
this is why fuckwits should not be allowed near electronics…
or oxygen
