[Matthias] sent us this project where he builds an AVR light controller. He had a halogen bike light laying around, but was unsatisfied with its lead-acid battery. He wanted to use a lithium-polymer battery but found that they can’t be used directly with halogen lamps due to their voltage. His produced 8.5 volts at full charge and can’t be discharged to below 5 volts. He new a power controller would be necessary to try to flatten that out for his lamp, which needed to stay between 6-12 volts.
He used an ATtiny45 doing PWM to change the voltage. Some other cool features he added were the high and low settings and an LED status light for warnings. You can find pictures, schematics and source code on his page as well as tons of great information. Great job [Matthias].
