Halloween Props: Puking Pirate
With everyone’s favorite free-candy holiday approaching, [Slouriesr] set to work building a vomiting ghoul for his Halloween display. He’s calling it a puking pirate and it centers around a pump and some simple plumbing fixtures.
First, the vomit receptacle was made by adding a sink drain with a pop-up stopper to the bottom of a kitty litter bucket. The drain slows the evacuation of liquid into a five gallon bucket below. In that bucket you’ll find a float switch pump used to keep water off of a pool cover. As the bucket fills up the pump turns on and empties the water through a hose ending at the ghoul’s mouth. The result is a 20-second puke cycle sure to delight the trick-or-treaters. Sure, there’s a lot of work to be done to get this guy looking the part, but what a great idea!
Help keep us in the holiday spirit by sending the details on your latest prop build.
6 thoughts on “Halloween Props: Puking Pirate
  1. Very fun idea, but it needs more video! (At the same time, thanks for posting it early enough for someone to actually implement)
Leave a Reply to SmallfriedCancel reply
