Direct To PCB Etch Resist Printing
Here’s a step-by-step guide for printing etch resist directly to copper clad boards. Two methods of making printed circuit boards at home have long dominated as the favorites; using photo-resist, and the toner-transfer method. The latter involves printing board artwork on a laser printer and then ironing it onto the copper clad. We’ve seen some efforts to print toner directly to the copper, or to use ink to adhere toner and then heat fuse it, but this hack is the first one we remember seeing that uses an inkjet printer directly.
The best reason inkjet printing isn’t often used is do to the ink’s iability to protect copper from the etchant. This method uses MISPRO ink that is pigment based and will resist the acid. An Epson Stylus Photo R260 printer was chosen because you can get refillable printer cartridges which work with the ink, and they’re fairly easy to modify. In order to feed substrate through the device it needs some physical alteration to make room for the thickness of the material, and an ATtiny13 has been added to trick one of the sensors.
Unfortunately we didn’t find photos of the printed resist. But there is source code available for the tiny13 if you do give this a try.
[Thanks Pavlejo]
16 thoughts on “Direct To PCB Etch Resist Printing
  1. nearly all inkjet printers have cartridges that could be refilled using a syringe.
    At the moment i am trying to find a cheap flatbed plotter, to try another method by using a blueray laserdiode to print on photoresist.
    Now I read this, i will try to modify an old HP printer to do this.
  2. I’d like to make one of these. If I made one I’d want to use it rather than fiddle with it all the time. Are we at that point yet?
  3. @hubert: love the plotter idea; definitely want to try it with my old HP 7475.
    However, I don’t think your HP printer will work for the process in the article; AFAIK, they all use “bubble jet” heads that require vaporizing the ink. This process likely requires an Epson printer which uses piezoelectric heads.
  4. One correction: Printed PCB must be heated to a specific temperature (around 230C) to cure it and make it etch resistant.
  5. The first time i’ve seen this method was a few years back and it seemed to produce great results.
    I still find it complicated because of the printer modification and curing. And I don’t know how you could align the images if you want double sided pcbs.
  6. @bogdan: My thoughts exactly. If you have the layers printed out on paper, it’s fairly easy to align the layers using a pair of sewing needles.
  7. alignment wouldn’t be hard. Set up a drill press jig to notch the pc board slightly on the left and right sides, then drill out the printer carriage on both sides in a similar place and put some short pegs through the holes.
    Woodworkers solved these alignment problems long ago and have been getting surprising accuracy.
    Of course, once you have a two-sided board you need to build an automated driller. Next thing you know, you’ve DIY’ed a pc board fab facility. It’s probably easier to pay some rapid prototyping house unless you’re doing a longer run.
  8. Actually , the cost per starts paying of not on longer runs, but on many short or single runs.
    A friend of mine owns a design business. He uses his own fab gear for prototyping, then sends the debugged gerbers to a fab house for the run.
    Hone fab is absolutely not cost affective for more than 3 or 4 boards.
  9. This is good stuff. All they have to do is get a homebrew solder masking down and then we can circumvent commercial companies completely. This is the stuff that MAKES the Maker revolution.
  10. You can find a number of projects that work in a similar fashion (and solve similar problems) right here on HaD by searching for ‘DTG’.
  11. @hubert, I tried this a while back.
    Ran into a problem with driving the diode fast enough and other things.
    What I did do is work out a system of using an HP laserjet mechanism, scanner, 23K256 and burner diode/driver.
    The idea is that the 23K256 buffers the drive signal so that in “continuous” mode it outputs directly to the laser so it correctly indexes on each quarter rotation.
    The PC instructs the scanner to do a full A4 page, so as the head moves the entire board is exposed.
Leave a Reply to TerryCancel reply
