10 Meter Long Moving Light Show Is Mesmerizing
light-show
[Marcus] was recently commissioned to put together the electronics for a slick 10 meter long LED installation at the Hsinchu Biomedical Science Park Exhibition Center in Taiwan. While you might assume that he was asked to construct a large LED matrix, this project is a little bit different from what you probably expected.
The display is actually a long light tunnel made up of 30 moving triangles suspended from the ceiling. The triangle movement is governed by 60 separate stepper motors, while the lighting is provided by 30 HL1606 RGB LED strips he picked up from Adafruit. The display’s logic is handled completely by an XMOS controller, which is beefy enough to handle controlling all of the stepper motors and the LEDs simultaneously.
After he hand assembled all of the motor driver boards and tested things in his workshop, the whole lot was shipped over to Taiwan for assembly by the on-site crew. After a bit of troubleshooting, they were able to get things working properly, and the display looks great as you can see from the image above.
[Marcus] says that he doesn’t have video of the display in action just yet, though he will update his post whenever he does.
[Thanks, Paul]
13 thoughts on “10 Meter Long Moving Light Show Is Mesmerizing
  1. “But finally it was done, only to learn that there was a mistake in the MCP23S08 footprint. But no design is a good design without fix wires:”
    Top tip, if your going to make 60, you should probably test the first one that comes off the assembly line :P
    Looks super cool and trippy.
  2. It’s Taiwanese. There’s a big difference between the two countries. Pretty cool though. Looks like Hsinchu is close to Taoyun and IIRC Hsinchu is a stop on the high speed rail.
  3. I like that the chinese have no hangup about using pink lights, and it remind me of blossom and it’s pretty nice in lightshows.
  4. The particular tools and techniques used in a business
    succession plan will vary based on the goals and objectives of the four groups affected by the plan:
    the senior generation business owner, the junior generation family members involved in the business,
    key non-family employees, and family members not involved in the business.
    Caring For A Relative With Brain Damage: Make Sure You Have Support.
    Would you like your family to spend more time together as a family.
Leave a Reply to WhatnotCancel reply
