If you’re looking to remotely control things around the house, but can’t do it over the Internet or via WiFi, the TiDiGino just might have what you’re looking for. [Boris Landoni] from Open Electronics sent some information on the TiDiGino our way, and it certainly looks like a useful device if you’re in need of a solid GSM remote control module.
At the heart of the TiDiGino lies an ATmega2560, which is normally used in the Arduino Mega, so there’s plenty of processing power to go around. While the form factor differs just a wee bit from what you would expect from an Arduino, the TiDiGino sports all the proper connectivity to support any standard Arduino shield along with the requisite libraries required for use.
Through a contest/community effort, the TiDiGino supports remote alarm, gate control, remote thermostat control, and DTMF remote control functionality right out of the box. We imagine that our readers can dream up a litany of other uses as well, since GSM remote control tends to be pretty popular around here.
Be sure to check out the Open Electronics site if you’re interested in learning more about the TiDiGino – you’ll find a complete BoM along with code and schematics, making it easy to build your own.
I have not read through the entire spec but it seems like it is an Arduino Mega and a custom GSM shield, has an audio input of some kind, and has two relays. (the following is a real question, I’m not being a jerk) What should make me want to buy this product instead of using already existing items?
Just to notify it’s Atmega2560 and not Atmega2650 ;-)
Just trying out the XHTML on an old post that got hardly any comments… hope this is ok. I’m always messing these up on everyday comments…
XHTML
MAIN SITE URL
abbr, Brett W. (hover for nickname)
acronym, Brett W. (hover for nickname)
cite, That’s what I said!
del datetime, what the? I guess this is like strike, datetime for mods only.strikeemphasized, same as italics
italics
strong
bold
MAIN SITE URL
cite, That's what I said!
italics
strong
bold
Hi, I purchased a tidigino to use with linux and mac osx, but my model seems to work only with windows and not with linux and osx.
I contacted the manufacturers, but he was not able to give me an explanation because they are only windows user.
With both linux and osx, the serial port is recognized, but the arduino ide go in time out when loading a scketch, while working perfectly in windows. do you know something about that? thank you!
