Fixing The Control Scheme For An Aftermarket Headlight Assembly
The headlight enclosures on [Bill Porter’s] 2004 Passat had yellowed with age and were not outputting the kind of light they should. He decided to replace them with some aftermarket modules that also incorporated LED strips. When they arrived he was surprised at how easy there were to drop into place. But when testing he was certainly not satisfied with how they worked. The day-driving mode used the HID bulbs at full power, where the factory assembly had dimmed them during the day. He set out to alter the electronics to work as he prefers.
Always the mad scientist, [Bill] started off by making a truth table showing how the lights reacted to the various states of the ignition and headlight switches. What he came up with is an AND gate built from a relay and diode. It allows him to have the LEDs on as the running lights (without the HIDs on at all), and leaves the rest of the functionality unaffected.
18 thoughts on “Fixing The Control Scheme For An Aftermarket Headlight Assembly
      1. Nope… It simply gives a US car an extra position to run just the parking lights. Your LEDs would run but so would the front ambers and the tail lights. Besides, plug and play is nowhere near as cool. :)
      2. I though I checked the wiring for my B5.5 passat, and the OEM night lights in the fixtures (Where the LEDs get their power in the new fixtures) were on the same circuit as the running lights and no switch could have changed that. But I could be mistaken.
        Either way I got what I wanted for under $15. Those Euro Switch look pricey.
  1. Looks like Bill will be buying a lot of HID bulbs and ballasts over the years….
    If the HID system is not designed for the Dimming, it will damage the system. Most specifically the low grade dog food that is the china aftermarket HID junk.
      1. @bill – Actually, you were punked into responding to our resident troll. @fartface -never- reads the articles he comments on, and only makes negative posts. I think he came to HAD because no one was noticing him on Slashdot.
  2. Pretty cool. Usually on this site, I expect to see someone have to modify some firmware, download a bunch of crazy drivers, construct an arduino sheild, blah blah blah. Nice to see a hack on this level for a change.
  3. Let us hope he adjusts the headlights correctly. The vast majority of people on the road with aftermarket headlight modifications end up being hazards, as they are poorly aimed, and end up blinding other drivers (not a good thing, it turns out.) Not to mention the common misconceptions about headlight color/ visual clarity.
    As for the electronics, it looks like he did a good job!
Leave a Reply to steveCancel reply
