Hackaday Links: September 11, 2012
Xbee sensors at Lowe’s?
Lowe’s, the home improvement big box store, is selling some home automation items which might be Xbee compatible. They’re being sold under the brand name Iris. There is some debate as to whether they’re Xbee, or just 802.15.4 hardware. Either way they might be worth checking out for your wireless projects.
Father sword replica from Conan the Barbarian
Sometimes its just fun to watch the master at work. In this case it’s a blacksmith replicating the sword from Conan the Barbarian. [via Reddit]
LG washing machine that phones home
LG has built an interesting troubleshooting feature into some of their washing machines. This video shows the encoded audio it will output if you use the right button combination. You’re supposed to hold your phone up to the machine while talking to customer service and they’ll be able to get some type of debugging information from the dial-up modem type of sounds. If you end up decoding this audio we want to know about it! [Thanks Pedro]
MicroSD card adapter for Raspberry Pi
[TopHatHacker] was surprised to see a full-sized SD card slot on the Raspberry Pi. His temporary solution to get his microSD card working was to uses a miniSD adapter. He cut away the case and bent the pins until they lined up with the microSD card.
Batman’s cowl for retro motorcycle enthusiasts
Okay, we think this Batman cowl in the style of 1950’s motorcycle garb is pretty cool. Just realize that if you’re seen wearing this you will be thought of as one of the crazy guys in town. [via BoingBoing]
12 thoughts on “Hackaday Links: September 11, 2012
  1. There is an Android app for the LG diagnostics. I am a TV and appliance repair tech and use it from time to time. Its also on some of their other products like dishwashers, fridges, and dryers.
  2. So this post reminded me that solid state hard drives tend to be mostly empty space… and it turns out this is also true for the new cheap 8GB transcend SD cards I got from Amazon yesterday:
    http://n3ox.net/files/transcend_sd_8GB_xray.jpg
    Quick snip with a pair of scissors and I’ve got a working short SD card that sticks out about an eighth of an inch from the board edge on the Raspberry Pi.
    Shows up no problem on my laptop… will grab an image from my working RPi card and stick it on there. I wanted to do a backup anyway.
  3. Re: LG Smart Diagnostics, I found interesting patents titled DIAGNOSTIC SYSTEM AND METHOD FOR HOME APPLIANCE. Go to patents.google.com, search for DIAGNOSTIC SYSTEM AND METHOD FOR HOME APPLIANCE, click on one of the results, then click Download PDF. The actual implementation may vary from the patent, but hopefully the information is a good starting point. I see “zero” is 2.6 KHz tone and “one” is 2.8 KHz tone. I don’t have enough motivation right now to wade through the patentese to understand the higher level data structures and learn enough audio manipulation to analyze if the sound from the video matches.
Leave a Reply to Filipe YaBa PolidoCancel reply
