Arduino Parking Lot Attendant
Here’s an automatic parking gate for toy cars. There’s no need to press a button, the electronics detect the presence of a vehicle on either side of the gate, raising it after verifying that the lot is not already full. It’s the same idea as counting how many people enter a room in order to switch the lights but the hardware is just a bit different.
The system is controlled by a pair of sensors in the paper which serves as the parking lot. There are three sheets of heavy stock, the top and bottom both have aluminum foil on them, with the center layer  as a separator. There are holes cut in the separator where the hash marks are seen above. By adding a little pressure to the car when you drive it up to the gate this completes a circuit instructing the Arduino that there’s a vehicle in position.
You can see a demonstration, as well as the guts of the build, in two videos after the break.
[via Reddit via Freetronics]
25 thoughts on “Arduino Parking Lot Attendant
  1. I think this is a great thing to show kids (I didn’t say just boys) when they have their Matchbox garage.
    Now add a license plate reader or RFID to each car…lol.
    1. Given the price of RFID stuff these days, that’s actually feasible.
      The model train nerds do that to ID rolling stock on their setups.
      If you grab just the last byte from the code you can get enough codes to avoid clashes and make coding easier.
      (Why is another story, and the answer of course is ‘why not?’)
  2. Too bad you left out the bit that slashes your tires when you try and sneak in through the out gate! (You could’ve put in a little shocker if you really didn’t want a row of pins to slash your fingers)… Just saying…
  3. I think it’s pretty cool though I would have worked it differently. You could use a magnetic sensor as the cars are all metal and you could detect the eddy currents.
    Or you could use an infrared laser and sensor.
      1. Yeah – it’s because they are passive sensors. If they were active it might well pickup the eddy currents in the aluminum frame.
      2. Then that’s clearly a nice advantage to being poor. Me in my ancient gas guzzling steel beast has no trouble turning those lights. :)
        I lied, I drive a Taco.
        I’m still poor though. :D
  4. To make this realistic, you need to make one of the parking spaces so small that no car can fit in it. That way the last person has to drive around looking for a space when the garage says it’s not full.
  5. This is actually very neat. I’d be entertained by this for like 3 weeks if I was a kid again. But just 3 weeks, it’s not THAT cool :P
  6. I like how some of the cars had to make 3 point turns instead of just pulling impossible low speed drifts.
    a small bit of refining and finishing, and I could see this as a marketable toy. maybe even a fancy lego set as an intro to the mindstorms series.
    –or scale it up and manage your own parking lot somewhere.
  7. Im doing something like this with a keil board for a project, does the software code differ much as I have to write the code in Keil
  8. You cant consider one slot less if a car enter on the parking, am I wrong?
    Because, one car can just enter the park, let one person and leave. He’s not going to park anywhere.
    You can count less one slot if he definitely park, using sensors on each slot.
Leave a Reply to ColignyCancel reply
