[Ben Krasnow] built his own version of the TSA’s body scanner. The device works by firing a beam of x-rays at at target. Some of the beam will go through the target, some will be absorbed by the target, and some will reflect back. These reflected x-rays are called ‘backscatter‘, and they are captured to create an image.
In [Ben]’s setup a rotating disk focuses x-rays into beams that travel in arcs across the X-axis. The disk is moved along the Y-axis to fill in the scan. On the disk assembly, there is a potentometer to measure the y-axis position of the beam, and an optical sensor to trigger an oscilloscope, aligning the left and right sides of the image. Using these two sensors, the scope can reconstruct an X-Y plot of the scan.
To detect the x-rays, a phosphorous screen turns the backscattered x-rays into visible light, and a photo-multiplier amplifies the light source. A simple amplifier circuit connects the photo-multiplier to a scope, controlling the brightness at each point.
The result is very similar to the TSA version, and [Ben] managed to learn a lot about the system from a patent. This isn’t the first body scanner we’ve seen though: [Jeri Ellsworth] built a microwave version a couple years ago.
The impressive build does a great job of teaching the fundamentals of backscatter imaging. [Ben] will be talking about the project at EHSM, which you should check out if you’re in Berlin from December 28th to the 30th. After the break, watch [Ben]’s machine scan a turkey in a Christmas sweater.
Hacking is fine, hacking with X-rays strikes me as a bit over the edge…in the sense that if you don’t know what you’re doing, you could end up hurting people other than yourself.
X-rays and radioactive stuff are further than I care to go at home.
As a guy with both radioactive substances and dangerous UV experiments running at home… Safety is all relative.
I’m not sure what “safety is all relative” means. If you mean, some things are relatively less safe than others, then I agree, but from the context you seem to be minimizing safety concerns. Someone playing with microcontrollers and electronics at 5V would need a freak event of biblical proportions to be harmed. Not so with x-rays, radioactivity, dangerous chemicals, lasers, or various other things. I’m not saying people shouldn’t hack with them, but I would hope those people have had some training and aren’t learning as they go.
Relative to your understanding of the subject.
This!
Correct. Anybody who just assumes X-Rays and explosives (and the ilk) are “over the edge” are just showing their own ignorance to the topic. Ben is one guy who knows what he’s doing well enough to be a great amateur.
It wouldn’t be HaD if the safety police didn’t come out at the mere mention of explosives / radiation / HV / PVC under pressure / running with scissors. Glad to see that survived the new layout.
The thing with such stuff you just mentioned is that if the inventors of these would have tought along the same line, we would not have such wonderwul things to play with.
This does not mean that the there is no need to take caution and that there is no need to educate yourself about the possible risks.
Ask madame curie about radiation?
And Edison about x-rays. (Yes, I know he didn’t invent it, but neither did Curie invent radiation.)
@Albert @andar_b
Are you suggesting that they should have not experimented with that because they did not know if it was safe enough?
Exactly! We need more experts, like the good folks at TSA. The slack-jawed droolers in the airport really look like experts to me.
No! Go go go, as far as you can.
Don’t play with X-rays.
I’m glad people with that attitude weren’t heeded in 1895. I like not having my leg cut off if it breaks.
Very impressive! Given:
1) The size of the phosphorescent screen, of which the entire area acts as a detector at all times
2) The use of a photomultiplier
3) The scanned and focused x-ray source
The actual x-ray exposure *might* be very low, just like the real thing. And I don’t expect [Ben] will point it at himself too often. So I’m not going to jump on the safety bandwagon this time.
The Real thing is not low level, in fact they never really released the research. Too Scared that we’ll find out the risks.
I’ve watched all of Ben’s videos. The guy builds things that are so over my head I don’t know where to start. I’m not sure what I like more, the fact he built a body scanner in his garage, or that he dressed a turkey in a sweater to test it. Classic…
God damn that was fast. It seems like only two or three weeks since he put up the video about getting the x-ray tube driver working.
My mom forbid me to play with X-rays…
I wish my Mom would have forbid me…
Hey, this is _exactly_ how the Mechanical TV transmitter works at the Early Television Museum:
http://www.earlytelevision.org/mechanical.html
I didn’t find a description of the TV camera, but they projected a scanning light in a dark room, and had one huge “back scatter” detector. I guess one big difference is, most light back scattered or absorbed, not much light went through…
What a bunch of safety dorks. Be informed and cautious, not fearful.
This is a remarkable hack! I am most impressed. It would be interested to see this paired with some sort of computer vision.
Remember three things:
– Marie Curie died of cancer(?) due to radiation poisoning
– Radioactive Boy Scout
– It’s not what you know, it’s what you don’t know that will get you (and others) hurt or killed
Have fun and be safe.
I think I’m one of the ‘Safety Freaks’ that people are complaining about.
But please keep in mind that X-ray radiation driven by a vacuum tube is a lot different than having radioactive dust all over your house.
And this is Ben we are talking about. I am sure that the man will die in a fireball, but given that he’s still alive he must know what he’s doing.
That maxim “It’s what you don’t know. . . ” is like trying to prove a negative.
I forgot to mention that you shouldn’t try this unless you know what your doing in the post, and a few people brought it up, so I’ll say it now: don’t try this unless you know what you’re doing. Be safe!
After watching the video,the scan is quite clear. It’s a terrorist turkey with an Allen wrench! Nice drumsticks!
The target object hidden under the garment should have been a carving tool or scissors something more recognizable, maybe a toy gun.
You are right – these detectors do not detect normal people (or chickens). That is the whole point of it.
What happened to the turkey after being bombarded with X-Ray? Did it come alive and become Hulkey?
That would require Gamma rays, which everybody knows require a green filter over the photomultiplier. XD
Nah, the TSA just gave it a cavity search and sent it to Gitmo! Very nice hack!
So, as someone who has a hobby with X rays, it would be wise of this fellow to have any instrumentation whatsoever that would give him an idea of whether or not he was getting cooked…like an ionization meter (Victoreen 470A, etc.)…
Sorry to be pedantic, but don’t the airport scanners use mm wave? X-ray wavelength is on the nm scale.
Not all of them, there are two distinct types, one is backscatter x-ray, one is T-Ray.. I would choose cavity search over X-Ray….
What I forgot to mention in my last post is how great I find this project. This is hack-a-day, not nanny-a-day. Haters, stop being jealous — this project should be in the list for hack-of-the-year.
Good build.
Yes X ray safety is an issue, instead of scaring the young ones, lets spell out the dangers. Every single X ray photon is a form of ionizing radiation. If it hits the right spot on your DNA it can alter it, and cause cancer. You can not reduce the energy of the photons, only the amount of them. Most X-rays pass right through you, some don’t and the chances of a single photon hitting just the right spot is very small indead. That being said, there is NO SAFE LIMIT. It is purely a statistical game, twice the exposure = twice the risk of cancer.
On medical X ray danger see
http://www.newscientist.com/article/dn4621-medical-xrays-cause-thousands-of-cancers.html
I remember long ago seeing an ancient book of “electronics projects for boys.” The last project featured homemade x-rays with a bare x-ray tube, powered by an induction coil described as an earlier project in the book. Just clamp the tube in a test-tube holder, stick your hand between the tube and a piece of film and off you go. Pretty scary.
And I’ll add that instead of complaining, the safety monitors should be educating. That’s what Tyler did, and I learned something helpful, and maybe even applicable.
