DIY $6 Serial Cable For Vintage Apple QuickTake Cameras
diy-serial-cable-for-vintage-apple-cameras
Knowing he was a guy who liked electronics and taking things apart, one of [Erik]’s friends sent him a vintage Apple QuickTake 100/150 digital camera as a bit of a joke. [Erik] enjoyed the gift, but since his friend hadn’t sent the necessary serial cable he really couldn’t do that much with it. He searched online only to discover the cable is very difficult to find these days, and thus very expensive. So, being the handy guy he is, he built his own.
Starting with an Apple MiniDin8 Male cable, he cut off one end and attached the wiring to a RJ45 connector. That got plugged into a modular adapter with a DB9 Female Plug end and wired up. The procedure required no soldering, and cost less than $6. Awesome.
Unfortunately the lack of serial cable isn’t the only problem he faced. QuickTake isn’t compatible with newer Apple computers that use Intel. You have to either have a much older Mac, or use a Windows XP emulator. If that wasn’t bad enough, the cameras only want to save photos in QuickTake file format. Luckily, [Erik] documents how he overcome all these issues in his post.
[Thanks Erik]
15 thoughts on “DIY $6 Serial Cable For Vintage Apple QuickTake Cameras
  1. I’ve been working on something similar, a DyCam/Fotoman model 1. Their support and site are dead, but I did find an 8bit dos utility executable from Logitec that I plan to sniff the serial comms and re-write a driver for it…
  2. I think I have one of those cables in my old serial cables junkbox. It’s the same cable used for a Mac II era computer (1990s) to an Apple dial-up modem and can also be used with a really early Mac or Lisa (a/k/a Mac XL) to Imagewriter II.
    1. Unless the devil has a paperclip (and why would you have paper needing paperclips down there) he probably won’t be able to eject the soul without having to do a reboot first….
  3. Vintage doesn’t mean ‘old’. It means ‘old and high quality’, or the best of it’s kind. I don’t think I’d call anything Apple ‘vintage’
  4. You might be able to make it work with Basilisk II if you can forward the data on the serial port through to the emulator. Load the images with the original software running on a period Mac OS (7.5.5 is free on Apple’s website), then convert through QuickTime Pro or GraphicConverter. (Automate the process using AppleScript!)
Leave a Reply to Joe BonassesCancel reply
