CNC Tic Tac Toe
cnc-tic-tac-toe
This computer controlled physical Tic Tac Toe game is built from parts scavenged from common consumer goods. Specifically, the sled is made up of a combination of printer and DVD drive parts.
The build is delightful, and you can’t move on to the next feature until you watch it play a game in the clip after the break. The game board can move along two axes. It’s obvious from the image above that the printer ink cartridge sled has been reused to let the board move left and right. But the DVD lens sled hidden under the board lets it move forward and back. The piece of protoboard seen on the left is an IR reflectance scanner. The board moves systematically under this sensor. Whenever a black square (placed by the human player) is in play it prevents the IR beam from reflecting back. What you can’t see in this image is the yellow disc dispenser which is just out of the frame. It uses the DVD disc tray motor to place the computer’s pieces. We think this build is just begging to be turned into a Turing Machine demonstration.
If you liked this one we’re sure you’ll also appreciate CNC chess.
5 thoughts on “CNC Tic Tac Toe
  1. So many wasted cycles… passing over areas without scanning them, then scanning the whole board…
    Overall, it’s a cool build, but there is lots of room for optimizing the code.
  2. Are you playing buzzword bingo to get the phrase ‘Turing machine’ into as many posts as possible?
Leave a Reply to EccentricElectronCancel reply
