Fingerprint Scanner Both Simplifies And Complicates Opening Garage Door
Fringer Print Scanner Garage Door Opener
Opening a garage door by hand is a lot of work and a hassle, hence the advent of the garage door opener. Nowadays, some people may even say just pushing the button of a remote control requires too much effort. [nodcah] is one of those people so he came up with a fingerprint scanner that controls a pre-installed garage door opener. All kidding aside, it is a cool project that lets you into your garaage, keeps unknown people out and doesn’t require you to remember to carry a key or remote.
In the center of this project is an ATmega328 that runs a custom Arduino code. This ATmega328 is responsible for controlling a 16 character, 2 line LCD screen as well as communicate with an off the shelf fingerprint scanner from Sparkfun. The fingerprint scanner has a built in CPU, can store up to 20 fingerprints and does all its own processing of fingerprint scans. It then communicates to the ATmega328 with simple commands over serial Tx and Rx lines.
The ATmega328, LCD and fingerprint scanner are all mounted outside the garage in a 3D printed enclosure. If the wires for the internal-garage open/close button were just run straight into this outdoor module, anyone could open it up, short the wires and get into the garage. To prevent this, if the ATmega328 gets the ‘OK’ from the fingerprint scanner, then it sends a signal to an ATtiny85 that is inside the garage. If the ATtiny85 receives the correct signal, it will then actuate the garage door opener by shorting the open/close button contacts. This prevents anyone from sneaking into the garage.
[nodcah] did a great service to the community by making all of the part list, schematics, instructions and Arduino code available so anyone can easily put this project together.
Continue reading “Fingerprint Scanner Both Simplifies And Complicates Opening Garage Door” →
Bluetooth Security And Capacitive Sensing Tool Cabinet Handles
Locking tool cabinet
[Andy] needed a new set of locks for his tool cabinets at work, but not wanting to carry around another key (or to remember a combination!) he decided to throw this little hack together — solenoid locking, capacitive sensing, tool cabinet door handles.
To do this he’s using a Bluetooth low energy breakout board coupled with an Arduino, two solenoid locks, and two capacitive sensors. He’s modified a pre-existing iPhone app to control the system, dubbed: The BlueLock Control.
When [Andy] is present with his phone, the system can be activated, allowing for automatic unlocking the moment you touch the metal handle. Usually he leaves it unlocked for the majority of the work day, but as soon as the day is done it’s just a simple swipe on his phone to engage lock mode for the night. And just in case he’s also added manual push-buttons for both solenoids in case anything goes wrong with the capacitive sensors. Cool hack [Andy!]
While you’re at it, why not make a keyless entry system for your car using Bluetooth too?
