8 thoughts on “Broken Laptop Lives Again In Skull ‘n Wrenches Arcade Cabinet
  1. More information can be found on the wireless 360 receiver module from the xbox here : http://forums.xbox-experts.com/viewtopic.php?f=13&t=4029 In the zip file contains a .txt with all the possible commands that the module can receive. Sadly the module cannot tell you if controllers are connected.
    Here is my version of converting a module for pc use :
    http://imgur.com/m6A18Qb
    It uses an atmega32u2 , with 2 switches one to trigger the sync , and another that will turn off all connected controllers. Both boards are soldered together, then glued to a 5 1/4″ faceplate, a molex connector connects it to the onboard USB of my pc.
    http://imgur.com/RHcysV3
    But the original reason for my post was, even though NES and SNES are old , isn’t carrying 700 games , especially to a public meeting, breaking copyrights? With the HaD logo just below.
    Its not that I am against this, because I will admit I have those 700 nes / snes games on my own pc, but isn’t it a bit of a touchy matter?
Leave a Reply to carbohydratesCancel reply
