Arduino is one of those boards that has become synonymous with hacking and making. Since its introduction in 2005, over 700,000 official Arduino boards have been sold, along with untold millions of compatible and clone boards. Hackers and makers around the world have found the Arduino platform a cheap and simple way to get their projects off the ground. This weeks Hacket focuses on some of the best Arduino based projects we’ve found on Hackday.io!
[Niazangels] gets the ball – or ballpoint pen – rolling with Roboartist, a robot which creates line drawings. Roboartist is more than just a plotter though. [Niazangels] created a custom PC program which creates line drawings from images captured by a webcam. The line drawings are converted to coordinates, and sent to an Arduino, which controls all the motors that move the pen. [Niazangels] went with Dynamixel closed loop servo motors rather than the stepper motors we often see in 3D printers.
[Peter Edwards] is preserving the past with Tapuino, the $20 C64 Tape Emulator. Plenty of programs for the Commodore 64, 128, and compatibles were only distributed on tape. Those tapes are slowly degrading, though the classic Commodore herdware is still going strong. Tapuino preserves those tapes by using an Arduino nano to play the files from an SD card into the original Datasette interface. [Peter] also plans to add recording functionality to the Tapuino, which will make it the total package for preserving your data. All that’s missing is that satisfying clunk when pressing the mechanical Play button!
[Dushyant Ahuja] knows what time it is, thanks to his Infinity Mirror Clock. This clock tells time with the help of some WS2812B RGB LED. [Dushyant] debugged the clock with a regular Arduino, but when it came time to finish the project, he used an ATmega328 to create an Arduino compatible board from scratch. Programming is easy with an on-board Bluetooth module. [Dushyant] plans to add a TFT lcd which will show weather and other information when those power-hungry LEDs are switched off.
[IngGaro] built an entire home alarm system with his project Arduino anti-theft alarm shield. [IngGaro] needed an alarm system for his home. That’s a lot to ask of a standard ATmega328p powered Arduino Uno. However, the extra I/O lines available on an Arduino Mega2560 were just what the doctor ordered. [IngGaro] performed some amazing point-to-point perfboard wiring to produce a custom shield that looks and works great! The alarm can interface with just about any sensor, and can be controlled via the internet. You can even disarm the system through an RFID keycard.
Want MORE Arduino in your life? Check out our curated Arduino List!
That’s about all the millis() we have for this weeks Hacklet. As always, see you next week. Same hack time, same hack channel, bringing you the best of Hackaday.io!
Only criticism of the Tapuino is that it should have been engineered to fit into a standard cassette case
Well I’m looking into a proper board design at the moment and the cassette case may be possible, but probably not with the off the shelf components and so at a much higher cost.
Maybe I will build a custom one, one day to have the bragging rights :-)
p.s. just fixed my username…
I should also mention that the Tapuino now fully supports recording. You can save game saves and your basic programs back to the Tapuino. Additionally, with a daughter board, a real Datasette can be connected to the Tapuino and TAP files can be played back to and recorded from the Datasette.
I am working with a tap preservationist to make the Tapuino into a low cost preservation system.
Does the guy who made the arduino alarm system have a site? I want to see how he did the sensors.
I hate how hackaday.io is just a few pics and a single sentence. I want to read about how the project was done!
Just klick on that image….
I made that alarm, I will update the project soon because I want to improve the network system (i want to use a w5100)! Look here for updates: http://hackaday.io/project/2519-arduino-anti-theft-alarm-shield
Reblogged this on Imran's Tech Tips and commented:
Raspberry Pi & Arduino opened up the hardware to millions.
