Ro-Bow, The Violin Playing Robot
There are robots that will vacuum your house, mow your lawn, and keep their unblinking electronic eyes on you at all times while hovering hundreds of feet in the air. How about a robot that plays a violin? That’s what [Seth Goldstein] built. He calls it a ‘kinetic sculpture’, but there more than enough electronics and mechatronics to keep even the most discerning tinkerer interested.
There are three main parts of [Seth]’s violin-playing kinetic sculpture. The first is a bow carriage that draws the bow across the strings using an electromagnet to press the bow against the strings. The individual strings are fingered with four rubber disks, and a tilting mechanism rotates the violin so the desired string is always underneath the bow and mechanical fingers.
As far as software goes, the Ro-Bow transforms MIDI files into robotic mechanization that make the violin sing. From what we can tell, it’s not quite as good as a human player; only one string at a time can be played. It is, however, great at what it does and is an amazing mechanical sculpture.
Video Below.
9 thoughts on “Ro-Bow, The Violin Playing Robot
  1. I rolled my eyes and recovered my balance after watching the video. A camera is not a water hose at a fire.
    Hupfeld and Mills Violino did it better a century ago. The moving fingering is novel. They just did it with many thin fingers.
Leave a Reply to krs013Cancel reply
