If you’ve never seen a Strandbeest before, you’re going to want to watch the video after the break. Invented by [Theo Jansen], a Strandbeest is a kinematic work of art. An eight legged structure that walks around under wind power — or if you’re clever, an Arduino and some motors.
For a weekend project, [Remet0n] decided to motorize a toy version of the Strandbeest, and make it remote-controlled. The toy is normally powered by a propeller spun by the wind — making it very easy to replace with motors. You can pick them up for under $10 on eBay.
Using an Arduino Nano, two small 3V motors , a wireless chip (NRF24L01) and a L9110 H-bridge, he was able to create this awesome little remote-controlled device:
As far as remote-controlled Strandbeests go though, we love this Sphero controlled Strandbeest — I mean, who even thinks about coming up with something like that? Maybe I should make one for my Sphero…
The original Strandbeests are incredibly elegant hacks on their own
the video is broken try reuploading it or if there is something copyrighted that is being flagged then mark the video as private and give us the login and password or post it to thepiratebay
https://www.youtube.com/watch?v=uVKkW7GO1nU
uVKkW7GO1n <– video in article
uVKkW7GO1nU <– Video I have posted, I'm guessing a cut and paste error
Thanks!
Isn’t adding a motor to a strandbeest like putting a motorizing a sailboat?
I thought it would be interesting to put something like a windmill on a StrandBeest and at some reduction ration the torque of the windmill should be able to drive the StrandBeest *into* the wind.
Or even arrange two windmills and a differential that is controlled by a wind vane so the side of the StrandBeest that is further from the wind source goes faster and aligns the StranBeest into the wind.
Yea I thought of something like that too, kind of a “food seeking” strandbeest, if it could be made to work you could put it some place like the bonneville salt flats and the damned thing would run forever.
Both of you should really read up on the strandbeest things a bit, this is pretty much what they do (wind powered) the guy even made basic sensors and logic gates with air to stop his creations from walking into the sea, and ‘stomachs’ to store compressed air to use when theres no wind (so bscly, “storing food” for later)
Sadly i couldn’t really find a video covering all those aspects, so just google a bit for each.
Yes. Useful for when the wind ain’t blowing or your sails are ripped.
Or when your hamster is tired
https://www.youtube.com/watch?v=A3iP0NGDDao
awesome ..i like the walking robot ..
Our hackerspace had a 3cm plywood lipo-powered version the size of your car, with a cordless drill-size brushless motor controlled with a standard Turnigy RC tarnsmitter. I’m not sure where it went these days.
This is the last thing i would expect to be motorized, R.I.P to the beauty of a strandbeest…nevertheless, still a cool hack.
Last thing, really? Never crossed your mind? I was dreaming of strandbeest with a motor the minute i first saw it.
I don’t think it’s a sacrilege to motorize a strandbeest at all. The art of the strandbeest, imho, is twofold: One, the amazing mechanical arrangement and two, the fact that mr. Jansen’s beests are wind-powered.
This build focuses on the first part, and is quite well executed. I like it.
Ben
Human A designs a ‘mostly’ straight line linkage along with hundreds of other linkages. Publishes papers.
Human B realizes this linkage could be used for a walking mechanism and develops it further. Publishes papers.
Human C eliminates the frame this linkages is mounted to. Instead he creates a cluster of these linkages tied together. Publishes results.
Human D connects a turbine to power Human C’s creation and gains reputation as genius inventor artist.
Human E makes smaller toy version of Human D’s creation. Gets all the moneys.
Human F significantly improves the novelty of Human D’s old toy. Publishes online.
Thank you Humans. You’re all awesome.
HI, I’m the creator of this robot, if you are interested you can ask me question via the youtube comment system. There are a lot of informations in the video description.
I’ll call you Human F
There are some more mototrized versions out there:
https://youtu.be/VDPz-pgwL9M
