NixieBot Films Your Tweets
[Robin Bussell]’s NixieBot is a mash up of new age electronics and retro vintage components and he’s got a bunch of hacks crammed in there. It’s a Nixie tube clock which displays tweets, takes pictures of the display when it encounters tweets with a #NixieBotShowMe hash tag, and then posts requested pictures back to twitter. If a word is eight characters, it takes a snapshot. If it’s a longer message, NixieBot takes a series of pictures of each word, converts it to an animated GIF, and then posts the tweet. In between, it displays random tweets every twenty seconds. You can see the camera setup in the image below and you should check out the @nixiebot twitter feed to see some of the action.
nixiebot_05For the display, he’s using eight big vintage Burroughs B7971 Nixie Tubes. These aren’t easy to source, and current prices hover around $100 each if you can find them. The 170V DC needed to run each tube comes from a set of six 12V to 170V converter boards specifically designed to drive these tubes. Each board can drive at least a couple of nixies, so [Robin]’s able to use just four boards for the eight tubes. Each nixie is driven by its own “B7971 SmartSocket“, a dedicated PIC16F690 micro-controller board custom designed for the purpose. A serial protocol makes it easy to daisy-chain the SmartSockets to build multi character displays.
nixiebot_01The rest of the build is pretty straight forward. A Raspberry-Pi running Twython for Twitter communications, GrafixMagick for GIF creation, Picamera for taking pictures and GPIO libraries for controlling the display. The software to run all of this is hosted on his GitHub repository with some basic instructions on how to put it together.
A more detailed reference is available on the NixieBot blog. He’s designed a Pi shield board to house the high voltage modules, a 5V DC-DC converter and the Pi GPIO header. He’s probably got a few more to spare, so with a bit of luck in finding the elusive Nixie tubes, and some deep pockets, it ought to be relatively easy to build your version of the NixieBot.
And if the NixieBot has got your interest piqued, check out “The Art of making a Nixie Tube” featuring the work of [Dalibor Farnby].
8 thoughts on “NixieBot Films Your Tweets
  1. “Burroughs B7971 Nixie Tubes….current prices hover around $100 each if you can find them”. Quote supported by recent online auction results. Man.
  2. Did you ever get a kit put together for sale? I have some of these b7971 Nixie tubes I’d love to put them to good use instead of just flipping them on eBay.
Leave a Reply to adcurtinCancel reply
