A Tiny Bench Power Supply
One of the more popular projects for beginners in electronics is a power supply. Yes, you can always go to Amazon and buy a nice power supply, but unfortunately, we haven’t set up our Amazon affiliate links yet. Instead, we’ll have to go with the next best thing and check out [Tron900]’s mini bench power supply build. It’s extremely capable and cute as a button.
The design goals for this project were to build a small and compact unit using mostly salvaged and recycled components, with all through-hole circuitry. The best guide you’ll ever find for a DIY power supply is one of [Dave Jones]’ earlier video series going over the construction of an adjustable power supply based on an LT3080. [Tron] didn’t have this regulator on hand and wanted to base his design around an op-amp instead. After rummaging through his parts, he found what he was looking for: a TIP3055 power transistor, a neat enclosure that could double as a heatsink and an AD680 voltage reference.
The design of this power supply was simulated in SIMETRIX, and after a few revisions [Tron] had a circuit that worked reasonably well. The circuit was populated on a piece of perfboard, a fantastic front panel was constructed, and one of those ubiquitous volt/ammeter panels added.
This is just a one-off project, but the results are fantastic. This is a very small, very capable power supply that does everything [Tron] needs. It’s accurate enough, at least when measured with a fancy benchtop HP meter, and looks adorable. What more could you want in a benchtop power supply?
22 thoughts on “A Tiny Bench Power Supply
  1. Cute, but it has a couple of beginner errors in it. Since the LM324 input range does not cover the positive rail, he used a divider, which without matched resistors is quite bad for common mode rejection. Also learned this lesson the hard way. Extra: it becomes very slow because of the triple slow op-amps which control the transistor in case of current limitation. This is also why it required so much output capacitance, which is not desirable for such a small supply.
    I would recommend instead to adapt his parts to the electronics lab power supply design, even using the fancy reference instead of the one with zenner diode.
    Still, I admire the project, but has a few things to fix.
        1. ^THIS!!
          HA!
          we shall both burn in a violent hell for mentioning gender in such an overtly biased (and yet statistically supported!) opinion!
  2. Dave Jones’ series was pretty good until he decided to scrap the “down to 0 volts output” spec. I think he changed it (which is the one thing he told people NOT TO DO in the first or second video) to a minimum of 1.2 volts, which is terrible.
    1. He did a lot few weird things in there, like using the expensive LT3080 almost as a simple tranzistor just to try and reach 0V. A negative supply would have fixed things easier and end up allowing real zero output (note his will still not output zero in case of an overload).
      [Says the guy who never managed to finish his own design….]
      1. My school had a design like this (and we where not allowed to change the design, flowers are red, etc.) it used a -3V reference. When switching off the supply, unplugging it, something else tripping a mains breaker or in case of power loss, the capacitors of this -3V reference would run out first, resulting in a 3V jump of the reference and also in the power supply output. This was 20 years ago when my ARM computers needed a 1.5V core supply and 3.3V IO supply. The rest wast not that bad, but this single feature made the whole supply too dangerous to use.
      2. @electrobob: I haven’t examined [Tron900]’s design in detail yet, but you’re right – a well designed small negative-rail (e.g. charge-pump) source solves a lot of issues with reaching 0V, especially with linear regulator and (relatively simple) switching regulator designs. As for the “expensive” LTC part, I agree. LTC parts are expensive and sometimes hard to obtain in smaller prototype-level quantities. But there is a BIG advantage to using an LTC part: (usually) decent and Free (albeit not Open-Source) LTspice simulation! [Tron900] seems to take advantage of this (in a simple way). Unfortunately, as of my post-time [Tron900] does NOT share the LTspice simulation files with us on his hackaday.io project page (put sadface here). I would ask [Tron900] for these files to be included, but alas it seems I have to sign-up for a separate hackaday.io account first to comment there (not gonna happen HaD!)
Leave a Reply to AlexCancel reply
