3D Printing T-Shirt Designs
Usually, t-shirt designs are screen printed, but that’s so old school. You have to make the silkscreen and then rub paint all over – it’s clearly a technique meant for the past. Well, fear not, as [RCLifeOn] is here to bring us to the future with 3D Printed T-Shirt Designs.
[RCLifeOn] affixes t-shirts to his print build platform and boom: you’ve got 3D printed graphics. He started by using PLA which, while it looked great, wasn’t up to a tussle with a washing machine. However, he quickly moved on to NinjaFlex which fended much better in a wash cycle. While the NinjaFlex washed better, [RCLifeOn] did have some issues getting the NinjaFlex to adhere to the t-shirt. With a little persistence and some settings tweaking, he was able to come out ahead with a durable and aesthetically pleasing result.
Now, 3D printing isn’t going to replace screen printing, but it’s also not going to replace injection molding. What 3D printing lacks in speed and efficiency, it makes up in setup time & cost. In other words, if you need 50 t-shirts of the same design, screen printing is the way to go. But, if you need 50 shirts, each with a different design, you just might want to follow in [RCLifeOn’s] footsteps.
Anyways, we don’t have much on 3D printing t-shirts, but we do have other useful information on 3D printing slinkys and 3D printing project enclosures. And, if you’d rather do it the old-school way, we can show you how to silkscreen all the things.
28 thoughts on “3D Printing T-Shirt Designs
  1. This screams for a permanent-ink inkjet print head or paint extruder rather than trying to mix molten plastic and cloth.
  2. Yeah….if only there were some way to print directly to garments using modified commodity printers…that would surely kill screenprinting and revolutionize the garment industry… https://youtu.be/E5FlwqbJsEk
    Pooping plastic on a Tshirt isnt an improvement on screenprinting and its a massive step backwards from DTG printing which has been done with modified epson printers over and OVER and OVER again for years.
  3. Line graphics only, nothing like sweating in one area under a big solid design. What about ironing the plastic into the weave?
  4. What’s with the hate? This is sweet. How many of us have DTG printers or are going to spend the hours to build one? Vs how many of us have 3d printers? I have a printer and some ninja flex ready to go, I’m going to try this out
  5. 3d t-shirt printing sounds great and I am sure it does, though very curious about the washing. You must be only hand washing and extremely gently which sounds labour intensive and t-shirts can get very grimy. Just how do you clean them?
  6. The ideas going through my head are unreal with what would look good as a 3d printed t-shirt. The obvious first one was a raptor or alien coming out of the shirt. Great article thanks.
  7. What about a compromise? Making the silkscreen stencil by 2d printing, even spitting resin and quick cure
    using an uv led?
Leave a Reply to AsifCancel reply
