In case you didn’t make it to the ISCA (International Society for Computers and their Applications) session this year, you might be interested in a presentation by [Joel Emer] an MIT professor and scientist for NVIDIA. Along with another MIT professor and two PhD students ([Vivienne Sze], [Yu-Hsin Chen], and [Tien-Ju Yang]), [Emer’s] presentation covers hardware architectures for deep neural networks.
The presentation covers the background on deep neural networks and basic theory. Then it progresses to deep learning specifics. One interesting graph shows how neural networks are getting better at identifying objects in images every year and as of 2015 can do a better job than a human over a set of test images. However, the real key is using hardware to accelerate the performance of networks.
Hardware acceleration is important for several reasons. For one, many applications have lots of data associated. Also, training can involve many iterations which can take a long time.
The presentation covers a lot more: a survey of tools, current hardware available, and the exploration of different kernels (algorithms) for use in different layers of the network. The real meat, though, is how to build hardware to best implement those kernels. Throwing parallel elements at the task is obvious, but the paper points out that memory access is the bottleneck. There are several strategies for reducing the cost of data access across the network. These strategies take advantage of data reuse and local accumulation of results. However, it is also possible to tune for lower power consumption by using a single memory pool at the expense of performance.
Towards the end of the paper, different memory topologies and devices get scrutinized. This includes using memristors and stacks of memory cells at the IC level. If you are looking for a complete but accessible survey of the deep neural network landscape, the first half or so of this presentation will be of great interest to you. The back part is a lot more detailed and if you are just a curious hacker, may not be that useful to you. But if you are developing ASIC or even FPGA architectures for neural networks, it is great stuff.
We’ve talked a lot about neural networks lately. There’s a host of classes and tutorials to get you started.
Naturally interesting, although it seems the bulk of it is done on the cloud side of things. Yes there’s recent talk of mobile, but that’s rather new.
The cloud has to run on hardware, though. This kind of research will improve everything from action cameras to server farms.
And the algorithms used in neural networks don’t use a lot of boolean decisions and do work best with a lot of memory bandwidth so the classic Von Neuman or Harvard architecture used in CPUs is a bad fit.
Hmm, I haven’t heard much from the field of wetware. It’d seem like a good alternative, if brain cells can be grown that aren’t as sensitive to damage and degredation.
Sorry but you cant use any of my brain matter. It is damaged way to much from all the drugs in my youth, and then the government brain washing got the rest. So I guess I’m almost brain dread.
And one last thing I keep hearing voices, There not bad. They just wont stop.
On the other hand I can offer my wife’s brain. It just keeps on going and going and going.(Maybe those are the voices I keep hearing.
But I love the idea.
Haha :-)
Awesome tutorial, thank you so much, I like this investigation area. https://hackaday.io/project/21964-artificial-neural-network
