Pumpkin Piano Promises A Gourd Time
Fall – it’s that time of year that brings falling leaves, Hallowe’en, and a pumpkin version of everything that you hold dear. In this case, it’s not a latte – it’s [Robert Vorthman]’s Pumpkin Piano.
[Robert] took a straightforward approach to the build, pressing a Raspberry Pi into service as the backbone of the operation. This is combined with an Adafruit breakout board for the MPR121, which is a chip that provides 12 capacitive touch-sensitive inputs. These are connected to the bountiful produce which make up the piano keys in this fun holiday hack. [Robert] uses some Python code that talks to fluidsynth, a software synthesizer that uses Soundfont files to create different sounds. It’s all wrapped up with some Neopixels that flash when each vegetable is triggered.
The build would make a great party piece for just about any fall gathering, and [Robert] has done a great job of rolling up all the hardware and software required in the write-up. For another take on a vegetable-based orchestra, check out last year’s Harpsi-gourd.
9 thoughts on “Pumpkin Piano Promises A Gourd Time
    1. Does the makeymakey control neopixels and midi synthesizers? I don’t think so. A Raspberry Pi and an MPR121 touch sensor is $40 combined. The makemakey is $50. The MPR121 allows all 12 pumpkins to be pressed simultaneously.
Leave a Reply to RF DweebCancel reply
