Creating A 3G Raspberry Pi Smartphone
It’s hard to believe, but the Raspberry Pi has now been around long enough that some of the earliest Pi projects could nearly be considered bonafide vintage hacks at this point. A perfect example are some of the DIY Raspberry Pi smartphone projects that sprung up a few years back. Few of them were terribly practical to begin with, but even if you ignore the performance issues and bulkiness, the bigger problem is they relied on software and cellular hardware that simply isn’t going to cut it today.
Which was exactly the problem [Dylan Radcliffe] ran into when he wanted to create his own Pi smartphone. There was prior art to use as a guide, but the ones he found were limited to 2G cellular networks which no longer exist in his corner of the globe. He’s now taken on the quest to develop his own 3G-capable Pi smartphone, and his early results are looking very promising.
Inside the phone, which he calls the rCrumbl, [Dylan] has crammed a considerable amount of hardware. A Raspberry Pi 3B+ with attached Adafruit touchscreen LCD is the star of the show, but there’s also a Pi camera module, battery charging circuit, and Adafruit FONA 3G modem (which also provides GPS). Powering the device is a 2500 mAh 3.7V battery, which reportedly delivers a respectable 8 to 12 hour runtime.
The case is 3D printed, and [Dylan] says it took a long time to nail down a design that would fit all of his hardware, keep things from shifting around, and still be reasonably slim. Obviously DIY phones like this are never going to be as slim as even the chunkiest of modern smartphones, but the rCrumbl looks fairly reasonable for a portable device. We especially like the row of physical buttons he’s included along the bottom of the screen, which should help with the device’s usability.
Speaking of usability, that’s where [Dylan] still has his work cut out for him. The existing software he’s found won’t work on 3G, so he’s going to have to come up with his own software stack to provide a proper phone interface. As it stands he’s made a call on the rCrumbl using command line tools, but while that might score you some extra geek points at the next hacker meetup, it’s not exactly going to fly for daily use. He mentions he would love to talk to any developers out there that would like to team up on the software side of the project.
We’ve covered one of the 2G Pi smartphones in the past, and of course the ZeroPhone is a very interesting project if you don’t mind the “dumb phone” interface. But if you’re looking for something that’s fairly close to commercial devices in terms of usability, you might just want to roll your own Android phone.
8 thoughts on “Creating A 3G Raspberry Pi Smartphone
  1. Yay for more DIY cellphones! SIM5320 is a really cool modem, but if you want to use it, better connect it through the USB port – you get whole 4 serial ports and a wwan0 interface, which is better than anything you could get out of that UART (like, there’s GPS on the thing!). Other thoughts:
    – ofono’s pretty cool, reliable and capable when it comes to GSM backends, though the barrier of entry is comparably high (since it uses a dbus interface, and you do need to spend a little bit of time learning the internals). If you want to seriously use your modem, calls, SMS, data and all, there’s hardly any better choices. Fortunately, we do have some sample code already – I’ll finish calls in November =)
    – if at some point you want a physically smaller modem, SIM5300 might just work for you (ZeroPhone has a breakout in the mod PCB repo, I have some spare PCBs for evaluation if needed). As for 4G, SIM7500 is very capable.
    – might want to use a bigger battery =) Hard to believe the power consumption is as low as it is, to be honest.
    1. There’s Pyqt and PyGObject or you could just make it in Qt in C++ Qt used to be owned by Nokia who used it for making phone UIs and it’s still used to make the UI for many interactive devices today.
  2. Why not use a modern SIM7100A if you are in the Americas or a SIM7100E in Europe? I have test driven both chipsets via uqmi and a couple of startup scripts in OpenWRT, Raspbian, and Ubuntu. LTE is widely available and we should no longer accept 2G and 3G speeds.
  3. This seems way easier with an orange pi 4g and the (android) phone display for it which is available at aliexpress.
