LED-ifying A Guitar, Part Two
An electric guitar is all about stage presence. Need to be cooler than a single guitar? No problem — there are double neck guitars. Need to be cooler than that? No problem, the guy from Cheap Trick has a five-neck guitar. Need to be cooler than that? Robbie Robertson played a guitar with an extra mandolin neck on The Last Waltz. Where do you go from there? Obviously, the solution is putting a TV in your guitar with a boatload of individually addressable LEDs in a guitar. That’s what [Englandsaurus] is doing, and the build thread is now getting into how to turn a bunch of LEDs into a display.
In the first installment of this build thread, [Englandsaurus] went over the construction of the guitar itself and how a hundred individually addressable RGB LEDs were installed inside two pieces of plexiglass. When the guitar is displaying white at full brightness, the power draw is 500 W. This, in itself, is remarkable; no sane person would ever plug a guitar into a 500 W amp, and even 100 Watts is just too damn loud. There’s more power going to the lights here than the amplifier, and that’s awesome.
Simply sticking LEDs in a guitar does not a build log make, so how are these pixels addressed? How do you make a display out of a bunch of LEDs? This is a hell of a problem, but with Artnet and Resolume Arena 6 these pixels can be mapped into a cartesian grid, and from there it’s just putting video on the guitar.
While the first installment of this build is great and shows you how far you can take electronics in a guitar, this installment is a great demo of turning a bunch of LEDs into a display, something that applies to more than just a gigantic glowey guitar.
10 thoughts on “LED-ifying A Guitar, Part Two
      1. i cant imagine all that digital noise would sound very good. you would have to go out of your way to shield the analog signal path to avoid signal contamination.
        1. Hold an e-cigarette 6″ from a humbucker and press the button. Interesting noise. Pluck an A on the LED guitar and it should shound like a Dalek with Flu, and an 80 a day habit.
  1. I wonder how much noise the LED’s put into the guitar signal. I also wonder what the guitar cord looks like. Need some decent sized conductors for 500W worth of LED’s/ I also wonder how warm it gets. I dunno, part of me thinks it is cool and part of me thinks a guitar ought to be made out of wood
  2. I bet John 5 is going to have one soon… I’ve seen him with a led lit guitar (granted they were all white) and I’ve seen him with a guitar with an LED screen built into it… This has to be the next logical step.
      1. There’s no difference between “tube watts” and “transistor watts”… obviously! Or is there another definition for a “Watt” then what is known by SI?
        I have on my desk 2 Genelec 8020 speakers which have 2x20w amplifiers and they put out ~105dB@1m per piece without distortion… That’s god damn loud!
        It’s all about good design. How well the amplifier is matched to the speakers, how the cabinet is designed, how sensitive the speakers are etc. etc. Stop peddling this audiophoolery….
Leave a Reply to jacobchristCancel reply
