A Contact Lens Launcher That Knows The Weather
They say that necessity is the “Mother of Invention”, but over the years we’ve started to suspect that her cousin might be an underutilized microcontroller. How else can you explain projects like the latest from [MNMakerMan], which takes the relatively simple concept of a contact lens holder and manages to turn it into an Internet-connected electronic appliance? Not that we’re complaining, of course.
He started out with a simple 3D printed holder for his wall that would let him pull out his daily lenses, which worked well enough and gained some popularity on Thingiverse. But he wondered if there wasn’t some way he could use a servo to automate the process. While he was at it, he might as well play with some of the components he’s been meaning to get some hands-on experience with, such as those little OLED displays all the cool kids are using.
Modifying his original design to incorporate servos in the bottom, he added a central compartment that would house an ESP8266 and a simple proximity sensor made from an IR LED and photodiode. The sensor tends to be a little twitchy, so he left a potentiometer inside the device so he can fine tune it as needed.
Strictly speaking the OLED display isn’t actually required for this project, but since he had a WiFi capable microcontroller sitting there doing basically nothing all day anyway, he added in a feature that shows the weather forecast. It’s not much of a stretch to say that the first thing you’d want to see in the morning after regaining the sense of sight is a readout of what the day’s weather will be, so we think it’s a fairly logical extension of the core functionality. Bonus points if he eventually adds in a notification to remind him it’s time to order more lenses when the dispenser starts getting low.
If you don’t have any contact lenses you need dispensed, never fear. A similar concept can be used to fire off your customized swag at hacker events. Don’t have any of that either? Well in that case you can always build a candy dispenser for Halloween.
10 thoughts on “A Contact Lens Launcher That Knows The Weather
  1. I like it, but the font looks so tiny. You’d need corrective lenses to read it. Maybe that’s why it’s built into a contact lens launcher? Grin
    1. I thought the same thing, but then I realized I don’t really know how one gets contact lenses. Can you just order them online, or do you need to go to the Dr?
      1. If you know your prescription then you can just get them online but you should go to the doctor if you dont know it
      2. I can only speak for Poland, but contact lenses and glasses don’t require prescription to buy, so you can just walk into a store, give them the specifications and have lenses made. For common prescriptions you can even get contact lenses from a vending machine.
  2. So the tiny display is to be used as an eye check device to confirm that A: you have insrted contacts, and B: they are in the correct eye.
