Poking Around Inside Of A Linux Security Camera
This deep dive into the Linux-powered Reolink B800 IP camera started because of a broken promise from its manufacturer. When [George Hilliard] purchased a kit that included six of the cameras and a video recorder, the website said they were capable of outputting standard RTSP video. But once he took delivery of the goods, and naturally after his return window had closed, the site was updated to say that the cameras can only function with the included recorder.
Taking that as something of challenge, [George] got to work. His first big break came when he desoldered the camera’s SPI flash chip and replaced it with a socket. That allowed him to easily take the chip out of the device for reading and flashing as he tinkered with modifying the firmware. After adding cross-compiled versions of busybox, gdb, and strace to the extracted firmware, he bundled it back up and flashed it back to the hardware.
If you think that’s the end of the story, it isn’t. In fact, it’s just the beginning. While getting root-level access to the camera’s OS would have potentially allowed for [George] to dump all the proprietary software it was running and replace it with open alternatives, he decided to take a different approach.
Instead of replacing the camera’s original software, he used his newly granted root powers to analyze it and figure out how it worked. This allowed for to sniff out some very suspect “encryption” routines built into the software, and eventually write his own server side in Rust that finally allowed him to use the cameras with his own server…albeit with a bit more work than he bargained for.
Projects like these are a fantastic look at real world reverse engineering, and a reminder that sometimes achieving your ultimate goal means taking the long way around. Even if you’re not in the market for a hacked security camera, there’s no doubt that reading the thorough write-up [George] has prepared will teach you a few things. But of course, we’d expect no less from a guy who runs Linux on his business card.
21 thoughts on “Poking Around Inside Of A Linux Security Camera
  1. While kudos for using the existing software, and I do get the effort and pain of using your own software, it is sad to see a mother propriatery piece not being liberated. It would have been much nicer to have seen a custom Linux distro that was open for these cameras …
    But with, scratch …
    1. Knowing the internal flash layout and the format update format, I probably could provide a firmware update that lets you log in, or even a custom distro. But it would be much harder to use the hardware capabilities of the system like the H.265 encoder since that info is all packed into the dvr binary.
      1. Yeah I figured it was that, so much binary blobbage and zero documentation for linux/android camera stuff, that it comes down to “did you actually want to use your camera at best quality, or did you want a blind dinky linux system.”
    1. I would try google but you have probability tried that.
      Perhaps try asking some Retro game cracking forums?
      ik they do a bit reverse enginering for emulators etc.
    1. They are intentionally crippled, these cameras have an equivalent that DOES output rtsp onvif etc (I know I have two in my system lol) these crippled cameras are sold much cheaper than the full fat versionstho I have no doubt the hardwares identical, if you could just flash the regular firmware you would probably be good to go.
      For those reading these reolink cameras, the full fat ones, do not require old IE plugins etc to be configured so perfect for someone like me who uses linux everywhere.
    1. or jsut buy the uncrippled version, there very reasonably priced, require no IE plugins to configure (i.e you can configure them from firefox/crome in linux) and of all the cameras i have tried over the years , in the sub £100 segment they are one of the best. IMHO ofcourse.
    2. “Should you buy this same camera knowing there is a hack or should you reward the brand that cripple the camera?”
      I dunno, ask the people who have bought Rigol O-scopes.
      (oh, wait! By posting your question on HaD, you ARE asking those people!)
  2. On a semi-related note, what recommendations are there for cameras and recorders that don’t have questionable security? I’ve looked at the Cloud Key Gen 2 (and related cameras) from Ubiquiti, but they don’t support anything but Ubiquiti cameras (and they seem like they are walling their garden in tighter and tighter, which I don’t like).
  3. Interesting. Anyone have a list or website characterizing all the choices for open and hi-res security cameras; please post links., including pin-hole cameras and other mixtures.
    Why would the stored video files be on anything other that a linux based system’s HD?
    Maybe on high bandwidth USB 3+ devices?
    Preparing for ports to usb4 should be in the works?’
    If I were to contribute code/fixes and other embedded goodies, where should I send such snippets?
    Thanks for this thread!
    James
Leave a Reply to Severe Tire DamageCancel reply
