Skee-Ball Scoring With Coin Slot Switches
Bowling is great and all, but the unpredictability of that little ball jump in Skee-Ball is so much more exciting. You can play it straight, or spend a bunch of time perfecting the 100-point shot. And unlike bowling, there’s nothing to reset, because gravity gives you the balls back.
In one of [gcall1979]’s earlier Skee-Ball machines, gravity assisted the scoring mechanism, too: each ball rolls back to the player and lands in a lane labeled with the corresponding score, which is an interesting engineering challenge in its own right. He decided to build automatic scoring into his newest Skee-Ball machine.
At the bottom of each cylinder is an arcade machine coin door switch with a long wire actuator. These had to be mounted so they’re close enough to the hole, but out of the way of the balls.
Each switch is wired up to an Arduino Mega along with four large 7-segments for the score, and a giant 7-segment to show the number of balls played. Whenever the game is reset, a servo drops a door to release the balls, just like a commercial machine.
The arcade switches work pretty well, especially once he bent the wire into hook shape to cover more area. But they do fail once in a while, maybe because the targets are full-size, but the balls are half regulation size. For the next one, [gcall1979] is planning to use IR break-beam targets which ought to work with any size ball. If you prefer bowling, you won’t strike out with break-beam targets there, either.
4 thoughts on “Skee-Ball Scoring With Coin Slot Switches
  1. Does the lane roll up into the main unit, or are those 2 rooms just no longer accessible? That’s some real commitment to skee ball!
  2. Score switches have always been the achilles heel of Skeeball machines and they are some of the most expensive tactile switches available for arcade/amusement machines. They take a lot of abuse from high speed, well weighted balls, and have some really long armatures that will eventually wear out from repeated strikes and throws; especially the midrange to lower score section.
    My $0.02: Go opto! Optical switches would have next to zero wear from direct contact and would be the perfect retrofit for any given skeeball machine.
Leave a Reply to JulianneCancel reply
