Grasp Kotlin’s Coroutines With This Short Tutorial
Kotlin is a relatively new programming language; a derivative of Java with lots of little handy functional bits such as coroutines. [Foalyy] is porting an app to Android and learning Kotlin at the same time, and after wrapping their mind around coroutines, has written up a concise five-part tutorial on them.
Coroutines in Kotlin are a way to simplify writing asynchronous code, which is code that doesn’t necessarily execute in the order it is written. Coroutines are like light-weight threads that can be launched and managed easily, making it simpler to bridge together blocking and non-blocking code. (However, coroutines are not threads. They are more akin to suspending functions that play very well together.)
[Foalyy] found that the official Kotlin documentation on coroutines went into great detail on how coroutines function, but wanted a more bottom-up approach to understanding how they work and can be used. Luckily for anyone who thinks the same way, [Foalyy] wrote it all up and begins with a great recap of important elements, but if you prefer you can jump straight to the examples.
Kotlin has been around for a while, and readers with sharp memories may recall it was featured in this excellent introduction to what neural networks are and how they work.
One thought on “Grasp Kotlin’s Coroutines With This Short Tutorial
  1. Every time I hear async and “coroutines” I think of Windows 3.0 “collaborative/reentrant multitasking”. I’m not saying it’s “the same”, but in the end it’s the same basic solution for the same problem, only now it’s embedded in the syntax.
Leave a Reply to GuilleCancel reply
