Where We’re Calculating, We Don’t Need No Seven Segments!
There have been many attempts at electronic numerical display technology over the decades since the first incandescent bulb or neon tube flickered into life at the command of a primordial computer, but the lowest common denominator has remained the humble seven segments. Here it might end, but for [Ken Yap] who has taken inspiration from a 1960s Sharp calculator to re-create a numerical display with only six segments.
This seemingly impossible feat is achieved by having six curved segments arranged as a figure-eight, which can render all the digits after a fashion, but which soon reveals why the extra segment made an appearance. The numbers that are made up of curves look good enough, but the straight lines in the 1, 4, and 7, are compromised by the diagonal, and the zero is curiously small at half the height.  You can read the digits, but it takes getting used to.
What made sense to reduce the complexity of 1960s electronics is only a fascinating curiosity in 2020, but we maybe won’t see these displays appearing too often. You can take a look at it in the video below the break, and if you’re curious about the Sharp calculator which inspired it then you can take a look at its page in the Vintage Calculator Museum.
22 thoughts on “Where We’re Calculating, We Don’t Need No Seven Segments!
  1. If you look at the article about the Sharp calculator, you will notice that its display is not 6 segments. It actually appears to be 9 distinct segments! There is a vertical full-height segment in the middle, that is used for the 1 and 4, and there appears to be a small dot to the right of the middle segment on the 4.
    1. 7 segments. The middle vertical one wasn’t two independent segments, and similarly, the little thing on the right of the 4 is part of the same segment that makes up the left side. So while some of the segments are split into two distinct parts, this still only requires decoding six segments, which was probably what they thought was enough savings to make it worthwhile.
      I think the Sharp 6-segment display was meant not just to be a little cheaper, but also to be MORE legible than 7-segment displays. Keep in mind that in the early 1970s, 7-segment displays were brand new, and did not look like either handwritten or printed numerals. By putting curves on their segments, Sharp was trying to fix that. It’s hard to imagine now, but 7-segment displays were unnatural when they were introduced, but that’s only because most people alive today grew up with them being as common as well-formed numerals.
      The video in this article does not appear to be the Sharp display, as it not only doesn’t include the vertical segment, but also places the digits too close together. I remember using one of those calculators, and it wasn’t NEARLY as annoying as the device shown in the video. Oh. I see, that was a hackaday.io project. Never mind.
      1. The Sharp QT-8D used the Itron DG10B with 9 segments:
        https://www.oldcalculatormuseum.com/sharpqt-8d.html
        (the 1 and 7 share the same lower line and the right part of 4 is separate)
        Here is the tube being driven directly, I think, as the 6 is different than on the Sharp:
        http://2.bp.blogspot.com/-uak3OR-xNXs/UdA-s7KTTuI/AAAAAAAAAzg/-Ym04N–0U0/s717/DG10B+ALL.png
        And some pictures of the unlit tube:
        http://www.jogis-roehrenbude.de/Roehren-Geschichtliches/Nixie/DG10BIN.htm
        The later Sharp EL-8 used a 8 segment variation of the Itron tube:
        https://en.wikipedia.org/wiki/Sharp_EL-8
  2. Interesting as an experiment, but as a result it is significantly less readable than that Sharp.
    Rather than sticking with a smooth figure eight, I can’t help wonder if there’s an adjusted layout of those LEDs that produces a much easier, or even easily readable result.
    1. As for the lower case o for 0, I remember reading somewhere that was actually by design-the early calculators with VFD tubes didn’t have leading 0 blanking and allegedly leading with oooo1234 was less distracting than 00001234 or something.
  3. I rather like obscure segmentation on display, one of my favourate is the Soviet IN-23 format which is like a 14 segement display but is only 11 segement as it has solid outer bars. It achieves readability by curving all internal bars to the mid point. Looks really good if you draw out the numbers…
  4. Chris E submitted the following comment in response to one of mine, so I got notified, but it disappeared from the comments:
    That’s interesting, reminds me of this 50+ year old clock on the main train station in Copenhagen
    https://ci3.googleusercontent.com/proxy/vRkdlHYulSgc50aXJV5WDZy3mv2A6GS_DVpDJQWDomDhA_-C6XzLmPttiKsIxvfE7Ab8s1aKpEGde5qFMVMWDAP0miAwjodfy7ZhLk8cfObAK_j1Ave5rH5Z4oX6qXDKQa9oOdNv-9wEnfk56K2YoOkzHiS3=s0-d-e1-ft#https://i.pinimg.com/736x/68/26/60/682660a7f27c66743e6ae94ae1f62580–train-stations-copenhagen.jpg
Leave a Reply to Chris WCancel reply
