On the scale of things worth worrying about, having to consider whether your EPROMs will be accidentally erased by some stray light in the shop is probably pretty low on the list. Still, losing irreplaceable data can make for a bad day, so it might just pay to know what your risks really are.
To address this question, [Adrian] set out to test just how susceptible to accidental erasure some common EPROM chips are. An EPROM, or “erasable programmable read-only memory”, is a non-volatile memory chip that can be programmed electrically and then erased optically, by exposing the die inside the chip to light at a specific wavelength, usually in a special chip erasing tool. But erasure can also happen in daylight (even if it takes a few weeks), so [Adrian] cooked up an experiment to see what the risk really is.
He exposed a selection of EPROMs with known contents to UV and checked their contents. Three of the chips had a simple paper or foil label applied, while one had its quartz window exposed to the UV. As expected, the unprotected chip was erased in just 30 minutes. The covered chips, though, all survived that onslaught, and much more — up to 780 minutes of continuous exposure.
So rest easy — it seems that even a simple paper label is enough to protect your precious retro EPROMs. It’s a good data point, and hats off to [Adrian] for taking a look at this. But now we can’t help but wonder: what would a little sunscreen applied to the quartz window do to erasability? Sounds like a fun experiment, too.
One question could also be how long will they survive in todays LED lighted rooms, which put out much less UV then say a fluorescent tube.
I want to see how long they would last with one of the silver “floppy disk write protect” labels over the window, like I used to use a couple of years ago. (OK, nearly 40 years ago).
Actually I have some 27c256 with checksums written on the silver label still, maybe I should check for myself ;-)
27c256!? We still use those at work! Though these days we buy them in plastic casing so they’re EPROMs without the window… so PROMs.
Those are called OTPROM for One Time Programmable ROM.
I’m willing to bet some have degraded. I’ve repaired a few pieces of early 80’s tech where the EPROM suffered bit rot. One was an early LED scroller sign. The EPROMS were MOS (pre CMOS). I don’t know if that played a factor. When they were cold they’d sometimes work, but once they got hot, the sign would crash. Those MOS EPROMS were total power pigs too, drawing 700mA each, so they warmed up pretty quick.
Luckily I found another sign from the same company that hadn’t been running for years on end. I copied it’s EPROMS on to their CMOS equivalent, and it started working reliably again.
You can also try to read them at reduced voltage (4V or so), the threshold voltage of the read amplifiers is a fraction of the supply voltage, so if they are “barely” readable, this can give you the headroom you need.
Programmers do the opposite thing and often verify at 6V supply, to be sure “it’s really in there”.
Not all EEPROM are created equal. I’ve left some of them in the direct sunlight for few hours and not a single bit was erased. After reading the datasheet and buying the correct wavelength UVC LED it only took a couple minutes at a few mW power to completely erase them.
actual UV-C LEDs are like $20-30 a piece
They start at about $5 from reputable suppliers. They one I use was $8.
You can use a standard UV LED. https://hackaday.com/2018/01/17/improvising-an-eprom-eraser/
Just for (possibly) longer exposure times. Although with folks mentioning 15 minutes that seems low.
I had some on a project near a window and had errors after several months. Not having labels didn’t matter when I was iterating and burning new revs regularly, but once I started working on something else there was trouble. Of course it wasn’t a big deal to just burn new chips and put lids on those.
Love Adrian’s Digital Basement, and was really shocked at how well just a piece of paper protected the eproms.
I want my 5 seconds EEPROM eraser back. Unfiltered Xenon PWM light for the win! It would be a great idea for an opensource project
https://www.youtube.com/watch?v=_sSuzDg4ntA
Wow! I’m surprised that works so well. It’s just a Xenon flash bulb?
yep, unfiltered Xenon light (Xenon light on 90’s photography flashes are UV filtered, thus unuseable as-is).
Seeing the comments of the video this particular device is a Zax Quick-EII (https://web.archive.org/web/20201023140659/https://reverb.com/item/28499982-zax-quick-eii-ep-rom-eraser) but I remember using big party xenon strobe lights with the UV window removed.
A modern, portable unit that erase eeprom in seconds would definitively be a killer device in some circles.
Pedantic: An EEPROM is an Electrically Erasable Programmable Read Only Memory. They are NOT UV erasable!
I stand corrected
I have that exact unit! Two flashes and you’re good to go.
Only did this stuff a few years ago a few times with that “Minipro” model in the background on an XP machine that has since died. I have the little disc of software that came with it. Since then I have tried and nothing on the disc works or any of the scary choices on the web either. What to do? I’ve got XP on a slim case with a Soundblaster sound card in it as a tape and vinyl transcriber. It’s worth a try.
Squirrel TV, me too. Too hot, they’ve gone outside for now.
If by minipro you mean the TL866 it won’t program many eeproms without modding. The Vpp in the application shows 21V as the max programming voltage but the device only puts out about 16V. You can still get the job done with an external power supply.
You got me interested here pal, I’ve got a TL866 and was disapointed to see it fail to program eeproms. Would you have some pointers about the mods?
I made an adapter using two DIP sockets. I bent the Vpp pin outward so it didn’t make contact with the programmer and attached a 21V supply between the ground pin and the EEPROM Vpp pin during programming. Check the datasheet to make sure the programming voltage is correct. I found this video that helped me. https://www.youtube.com/watch?v=VwxCpSt-3RQ
The schematic is online, as well as an open source firmware replacement. The programmer has two boost converters that create the programming voltages. Voltages are set by switching in different resistors in the voltage divider that feeds the internal comparator on the boost converter. Changing one or more of those resistors might be enough to get you there, although the entire boost converter should be reevaluated.
Why do we still need EPROM? Isn’t EEPROM better in every way?
Well given the channel the video is from, I’m going to guess mostly for vintage stuff.
EEPROMS used to be more expensive, but I don’t know if that’s true anymore. Electric eraseability only makes sense in equipment designed to self-program, especially if they’re more expensive.
Google Translate Amharic to English quote.
“I’m really grateful she was released this morning and thank those who worked hard for her release, and we’re glad she’s alive,” he said.
Try ROMulan 🙄
Xrays work also. I used to work at a place that tested EPROM die before packaging them, and they replaced the big UV “ovens” that took 30 minutes with a stepping Xray machine system that took about a minute to do the whole 6″ wafer. Yes, it was a long time ago.
So if I want to erase an eprom I should just put it in my mouth when I get an x-ray at the dentist?
Yeah but the dentist will probably tell you to cut down on your consumption of fish and chips
I headed that some old OTP ROMs and micro’s have EPROM’s but cannot be erased due to fact that they are in a non-windowed package. Maybe X-rays can erase these.
There may be configuration information in EPROM that is set by the manufacturer, stuff like package pin count or amount of working memory. If there is an ADC on board, trim information on the reference voltage. Other than that, yes, you should be able to erase windowless packages.
One other consideration is how hard the device was programmed. Spec sheets would indicate a minimum duration write pulse with the Vpp applied, and some programmers would just go with that, while ‘smarter’ ones would perform shorter writes but then read back and repeat until the ‘0’s were solid. End of the day it’s just about how much charge did you drive onto the floating gates. It’s going to be a product of Vpp and time. So did your burn just barely achieve enough for a ‘0’ bit? Or did you put it well over the threshold? The effect is of course cumulative, so that’s why if it didn’t take the 1st time you could often get it on the 2nd try.
Point being, a marginally burned EPROM is going to start losing its 0’s a lot quicker than a solidly burned one.
I seem to recall from back in the day that 2 weeks of sunlight would do it, so maybe a couple months near a window would also be a problem. We had neither in my lab, and the boards went into opaque enclosures, so it wasn’t a big concern.
Ha, 2 hours in the Florida once. Clean as a whistle, I I had just burned it in my home built programmer using the recommended time.
If you want to corrupt an eprom, Just use an old school camera with a flash.
Someone used an eprom as a cheap camera sensor. Exposure times were astronomical high but it worked quiet well.
Just write all zeros or all ones and start exposure through a lens and the object will be “written” to eprom.
IIRC there had some corrections to be made for non linear memory mapping.
Unfortunately I cannot find the article anymore.
https://hackaday.com/2014/04/05/taking-pictures-with-a-dram-chip/
Found it if anyone else if interested.
He’s talking about eprom, completewith a window on top. Sounds feasible, but I don’t recall seeing it done before.
As for dynamic ram, it actually goes back to the Cromemco Cyclops in 1975. It was going to be a project, and when the Altair came along, it was changed to a digital interface.
I ran across some windowed Microchip microcontrollers from the 1990’s not too long ago. They had been collecting dust on shelves for over 20 years, exposed to whatever was going on in the room at the time. Every one that I tested was happy as a clam with the stuff I had put on them way back when. Not that there were many bits to erase, but I suspect those things will still be there after the big solar EMP event wipes out the rest of our electronics.
I just cover the quartz windows with Kapton tape… It’s roughly the same color as Amberlith so I’ve always assumed it filters about the same wavelengths of light. Well enough, at least. Not like I go exposing EPROMs to direct sunlight just to see if I can accidentally corrupt them… 🤷♂️
The few UV EPROMs I’ve seen in my NEO-GEO MVS cartridges didn’t have any protection on the windows, so I guess it isn’t a huge concern, even in a production setting?
I remember a lot of devices that used EPROMS as logic without a micro. Some commercial arcade game boards were full of them.
I also remember, now accurately, predicting the 15-20 year data retention (quantum tunneling I think?) data sheet limit was going to come back and bite (byte?) them. I saw a real scramble of game restorers trying to find the data for their corrupted EPROMs.
I opened my big mouth once and bragged about wirewrapping a programmer into my homebrew when I wanted to rewrite my boot EPROM. I wound up with boxes of EPROMS from guys restoring arcade games hoping to recover the weak data. I worked out some algorithms and was moderately successful. The interesting thing was many could be restored right to the same EPROM. The part didn’t wear out, the data did.
Building the interface (Intell 8255 port with a transistor switch for Vpp) and figuring out the timing for programming the 25C32 was my first digital project for my homebrew. I think it was the first one to use a single 5V supply where as the 27Cxx needed +12v and the earlier ones needed a negative supply as well.
That 5 x minimum retention pulse algorithm I didn’t see pop up in the data sheets until the EPROMS started hitting 128k & 256k.
There may be configuration information in EPROM that is set by the manufacturer, stuff like package pin count and if there is an ADC on board trim information on the reference voltage. Other than that, yes, you should be able to erase windowless packages.
In my industrial experience with old CNC machine often problem is that glue on the stickers get old, and windows is not covered… So please make backup or check stickers :)
