3D Printing Steel Parts At Home Via Special Filaments
Rocket engines are great for producing thrust from fire and fury, but they’re also difficult to make. They require high-strength materials that can withstand the high temperatures involved. [Integza], however, has tried for a long time to 3D print himself a working rocket engine. His latest attempt involves printing an aerospike design out of metal.
Even steel couldn’t hold up to the fury of the rocket exhaust!
The project relies on special metal-impregnated 3D printer filaments. The part can be printed with a regular 3D printer and then fired to leave just the metal behind. The filament can be harsh, so [Integza] uses a ruby nozzle to handle the metal-impregnated material. Processing the material requires a medium-temperature “debinding” stage in a kiln which removes the plastic, before a high-temperature sintering process that bonds the remaining metal particles into a hopefully-contiguous whole. The process worked well for bronze, though was a little trickier for steel.
Armed with a steel aerospike rocket nozzle, [Integza] attempts using the parts with his 3D printed rocket fuel we’ve seen before. The configuration does generate some thrust, and lasts longer than most of [Integza]’s previous efforts, though still succumbs to the intense heat of the rocket exhaust.
Overall, though, it’s a great example of what it takes to print steel parts at home. You’ll need a quality 3D printer, ruby nozzles and a controllable kiln, but it can be done. If you manage to print something awesome, be sure to drop us a line. Video after the break.
31 thoughts on “3D Printing Steel Parts At Home Via Special Filaments
      1. Or rather he chooses to try things by himself. Like 3d-printing a nozzle and then just blasting some pure oxygen through it, which as we know, makes engine-rich exhaust. He is just goofing around. I don’t say it’s bad, it’s just reason why he is not like Elon. I’m also not like Elon.
        1. Elon isn’t like any of us. He isn’t an engineer. Just is able to attract the right engineers to fulfil his visions. With money, vision, persuasion, and anything else he has on hand that other people want.
          1. You should see recent Everyday Astronaut interview with him, It’s over 2.5h tagging along on site, but it’s worth it.
            Not “JUST”, he can attract right engineers AND talk to them to get the best results, because he undarstands them and has engineering skills himself, so he knows what he’s doing.
    1. Do you refer to something specific in the geometry? Because otherwise it’s an usually looking aerospike nozzle IMHO. And if you have seen them only in a comic book that’s very sad.
    1. Ahem, burning fuel rich. Otherwise the oxygen will combust the steel (actually a neat idea to do on purpose— I’ve heard of plans to send rockets to mars that arrive empty and then use the engines and tanks themselves as fuel.)
  1. …to burn off that scarce oxygen painstakingly wrung out from the already thin CO2 carefully scroll-pumped out of the Martian atmosphere.
    All that using up reams of solar energy harvested via eye-wateringly expensive solar cells sent from Mom’s basement (aka Earth), because the necessary manufacturing depth will take us ~150..~500 yrs to achieve.
    Kind of makes sense, yes ;-P
    1. Adblockers break it – I’ve found you have to allow typekit, wordpress and wp through or replies go to the bottom.
      Good of HaD to not fix it or make a little notice about it though…
  2. I’m still working my way up to trying it so mine is not an informed opinion… yet.
    But lost PLA casting makes way more sense to me than these metalized filaments that get fired.
    All ways to get metal look like a lot of effort. If I’m going to make that effort I probably am after the full strength of a solid metal part. I know the part shrinks as it fires which takes up some of the space that the plastic once occupied but on a microscopic level are there really no voids left by the burnt off plastic? Is the part really as dense as something that was made of metal to begin with? Are the layers fully fused with no chance of delamination?
    1. Casting and sintering both have their pros and cons and are useful for different things.
      Casting for instance is great for aluminum whereas when sintering there is a giant battle against oxidation. Meanwhile, copper is a pain to accurately cast but is one of the easiest items to sinter. Casting is great for a big bulk item where material cost is a bigger consideration but sintering may be way easier in terms of how much time you have to spend preparing each part when doing a bunch of small things.
      There are also geometry considerations: when casting, everything has to be connected together, so you can’t make chainmail for instance, whereas when sintering this is easy. All in all, having some variety in techniques available is good in my opinion!
Leave a Reply to Full Metal CasterCancel reply
