No matter what the size or shape of an LED, it brings out the curiosity in every hardware nerd, and is the lifeblood of badge life around the planet. Then there is the LED cube that takes LEDs to all sides — literally. [Tomverbeure] had his own adventure of creating an LED Cube by piecing together Pixel Purses and a Cisco3G Modem.
A quick search for Pixel Purse on the internet reveals a toy lady’s handbag with an LED matrix embedded in one side. [tomverbeure] tore down 12 of these so as to get two panels for each side of his creation. After a little bit of experimenting with PCB corner brackets, he finally got it right and he is able to merge the pieces together to form the cube.
Next comes the brain and the elected device An FPGA from an HWIC-3G-CDMA modem. Cisco routers have extension slots and the HWIC connector on this particular piece had usable GPIOs that connect directly to the Altera FPGA. Inside the FPGA, a RISC-V soft CPU is used to generate images that get processed and dispatched in a hardware block. [Tomverbeure] does a detailed explanation of the implementation for all the blocks which were written in SpinalHDL. The video below shows the project in action.
We love the detail that [Tomverbeure] provides and hope it does not drive up the prices of the pixel purse too much. If you are looking for a more fine pitched cube, look no further than this one. If you end up making your own, be sure to send us a link.
“provides and hope it does not drive up the prices of the pixel purse too much”
Read his post more carefully. He bought them when they were on sale for 6 bucks and he had to ask his colleagues for help as there was a 2 per customer limit. He says now they are back to regular price of 50 bucks. So you need $600 just for the purses.
Amazon has the pixel purse at $15 USD today, maximum quantity of 3 per purchase.
Hub75 panels will serve as an easy replacement for the purse ones.
The purse uses a hub75 panel, it was the cheapest way to get them at the time (might still be)
Ah yes – I’ve looked at the article now and it clearly says hub75 on the PCBs…
Those “Smart Pixel Purse”s are now about half the price on Amazon, than when the article was posted.
https://www.amazon.com/Project-Mc2-Toy-Light-Purse/dp/B071LQR2QG/ref=sr_1_1?crid=1SS08EQB7WWQN&keywords=Smart+pixel+purse&qid=1643132442&sprefix=smart+pixel+purse%2Caps%2C113&sr=8-1
