Animatronic Puppetry Controller Skips Joystick Or Keyboard
One of the major challenges of animatronics is creating natural looking motion. You can build something with an actuator for every possible degree of freedom, but it will still be disappointing if you are unable to control it to smoothly play the part. [Mr. Volt] has developed a passion for animatronic projects, but found programming them tedious, and manual control with keyboard or controller difficult to do right. As an alternative, he is building Waldo, an electronic puppetry controller.
The Waldo rig is being developed in conjunction with [Mr. Volt]’s build of Wheatley, the talkative ball-shaped robot from the Portal 2 game. The puppetry rig consists of a series of rings for [Mr Volt]’s hand, with the position of each being read by angle sensors. This allows him to control Wheatley’s orientation of the body and eyeball, eyelids, and handles. Wheatley and Waldo both still need a few refinements, but we look forward to seeing the finished project in action.
The Portal games have inspired several featured projects, including GLaDOS, the turrets, and of course more Wheatly builds.
2 thoughts on “Animatronic Puppetry Controller Skips Joystick Or Keyboard
  1. quite promising experiments, although my feeling is that “old fashioned mechanic/hydraulic controls” were quite good if used by skilled people …
    1. If all you want is a puppet I would say it stupid to do it electronically (or at least as electronically as this is). The simple to build and use cable and hydraulic systems seems like a massive winner for the bulk of puppetry movements, add in some electronic and control sticks or buttons for the extra details and those joints that really don’t suit..
      But the fully electronic has some major gains if you want anything more than just a manual puppet – you can record your inputs and have it run on its own for instance. You also don’t need to be so good a puppeteer – as you can apply motion smoothing etc so each element moves realistic/consistently. And then there is the most fun bit IMO of a fully electric build of something like this, it can be the avatar of your home assistant, look at you creepily when needed…
Leave a Reply to Nitpicker SmartyassCancel reply
