Miniature Motorized RC Car Is Massively Impressive
Small is often subjective. For example, a school bus is small compared to an Airbus A380. But other things are just small all on their own and need no comparison to make the point. Such is the case with this micro RC car in the video below the break. It’s an RC model of the Smart Car, that when compared to other vehicles on the road, is quite diminutive, both subjectively and absolutely. But the outward appearance of [diorama111]’s project only tells half the story.
Starting out as a static display model, [diorama111] fully disassembled the 1/87 scale Smart Car and got to work. Fully proportional steering is attained with a very, very small stepper motor that drives custom knuckles attached to handmade suspension. They are works of art in their own right.
Do your projects need tweezers for assembly?
Drive is supplied by another small stepper motor. If [diorama111] had stopped there, it would have been every bit as noteworthy to see a 1/87 Smart Car doing figure eights around small bottles of model paint. Instead, [diorama111] kept going! The car has working turn signals, brake lights (including the 3rd taillight in the back window!) and headlights. There is even a function for hazard lights.
The electronics are all hand built using enameled wire and SMD components on perf board, and are a study in miniaturization all their own. An ATtiny processor seems right at home in this design. We admire [diorama111]s steady hands and patience to build such a small RC car, never mind one with such fine attention paid to all the details.
If downsized hacks like this float your thimble-sized boat, you might also appreciate this precious little PDP-11 and terminal.
Thanks to [furby73] for the great tip!
32 thoughts on “Miniature Motorized RC Car Is Massively Impressive
      1. I don’t want this to come off wrong absolutely amazing on the build and the thought that went into this.
        I have only one question why a motor for steering and not just a linear servo?
        1. A servo would require the addition of a potentiometer and an analog input to read it. This way, it requires fewer parts, less room, and since it’s a stepper motor, just some calibration to center the steering, which it would need anyway.
        2. Looking more closely at the documentation, I see that he used an optical end-stop to determine when the steering reaches the right limit. This doesn’t seem to be shown in the video.
          1. He probably could have put a resistor in the ground circuit of the bipolar motor diver and monitor voltage increases when it get to the end of travel and us that to CAL center.
      1. Good point. The stepper already seems a bit loud. You can hear that it appears to take big steps steering in one direction and be smooth in the other.
        So yeah, just a bit of extra code and you would have a faint buy audible horn.
        Stereo might be a bit tricky. The steering is a bipolar stepper and the rear wheels have a brushed DC motor.
    1. Possibly. But it would also need to have a lot of layers otherwise he wouldn’t be able to pack the components so densely. 4 layers could not be enough to run all those signals – and then it gets into a very specialist territory (= expensive). With the flying wires he can have as many “layers” as he wants because he doesn’t need to worry about crossing tracks.
      A more logical thing would be to forgo the separate Bluetooth module and microcontroller but to use an MCU that has a built-in radio – e.g. a module with one of the nRF52 chips. Those can be had in very tiny sizes. On the other hand the programming is a lot more complex and it is Bluetooth Low Energy, not Classic …
  1. In every scene i can see what i would have done.
    Would have tweaked that metal plate into a pretzel chip,
    Lost that tiny part twice.
    Numerous punctures in my fretting fingers
    And sweep the whole thing on the floor with my sleeve cuff.
    Twice at least.
    Bravo!
    Eh, i like coffee too much.
  2. I still think it needs a tiny little horn.
    This is incredible. I’m impressed that even the lights were made functional. It’s amazing how small things have gotten these days.
  3. Yep, same guy who did the 1/150 scale RC car a year ago. But that was a Toyota Crown, so much bigger than a Smart. But he outdid himself with the lighting on this one.
  4. Very, very nice!
    But there is still room for improvement: he could use 01005 resistor/capacitor chips and XFBGA/UFBGA/WLCSP microcontrollers/ICs with 0.4mm PCB thickness and 3.5mil trace with, 3.5mil clearance and 0.2mm drill holes ;-)
    That would be the current technology limit!
    BTW, where can you find these little stepper motors?
Leave a Reply to vibCancel reply
