Can You Cheat At Tightrope Walking?
Tightrope walking is no mean feat — it takes years to master (even with a balance rod) — but that’s too much like hard work for [James Bruton]. Obviously, the solution is just a matter of the application of some electronically-controlled balancing technology, and [James] is just the guy for the job. Bearing a passing resemblance to a cross between a prop from Ghostbusters and a medieval torture device, this weighty balancing cheat device almost kind of works!
On a slightly more serious note, bipedal balance is a complex problem to solve. You have multiple limb sections, which can move independently in many ways, as well as the upper body also contributing to shifting around the center of gravity in a hard-to-predict way. So it’s no great surprise that a simple torque reaction device strapped to the torso doesn’t help a great deal, but it sure is fun to watch him trying. The bottom line is this — our bodies are pretty heavy, and the amount of force needed to correct tilt in the plane of interest is hard to generate without the reaction wheel itself being really heavy, and that extra mass doesn’t exactly help with the overall balancing problem. We reckon the overall concept is sound, it’s just that all those extra limbs flopping around make this simplistic sensing and compensation strategy only partly effective.
Stabilizing small robots is probably a bit easier than a human, such as this gyroscopically-stabilized monowheel, but sometimes you don’t even need the gyroscope, as you can control the driving wheels directly.
14 thoughts on “Can You Cheat At Tightrope Walking?
  1. What about a rig that can slide a horizontal rod back and forth? Seems like the rod wouldn’t even need to be all that massive. You’d get immediate reaction force when accelerating it, and also control over the combined center of gravity of the rig and wearer.
    1. Limb amputation more likely, since he will have to move his arms straight into the rotating blades’ path to walk…
  2. That is not a rope. That is a beam and walking across a beam is not that hard. I think James fundamentally lack and understanding of the inverse pendulum effect which is the reason we find it quite easy to walk and cycle without falling.
    1. That could have been an insightful comment, it’s a pity you tried defaming his intelligence and failed to get grammar/spelling right….
  3. watching that guy fall off the bar over and over, right at the beginning of the video, is like watching informercials where the guy can’t pour milk.
  4. The demos at the start of the video work because the pivot point is at the bottom. When walking and trying to balance you can see that he is pivoting at the waist in the opposite direction to what the mechanism is designed to correct. Either the device needs to be attached in a way to sense the tilt of the lower body, or perhaps because the upper body is instinctively tilting opposite to the lower body, reverse the direction that the device corrects.
Leave a Reply to ConsultingJoeCancel reply
