This Crosswalk Sign Costume Is A Halloween Hit
Halloween costumes can be anything from an expensive authentic recreation of a character’s garb, to a cheap knockoff bought from one of those overcrowded pop-up stores. Alternatively, you can get creative and conceptual about things, such as by building yourself a crosswalk sign costume.
The creation of [jared531], the build uses a large piece of cardboard painted black as the base. This sits behind the wearer, and is given a yellow outline to emulate the crosswalk signals common in the US. Red fairy lights are then laid out on half of the cardboard in a pattern emulating the “STOP” hand signal.
The wearer should then dress in all-black garb, and attach the flat cardboard panel to themselves with elastic straps. A black mesh face covering helps to complete the look by blending in the wearer’s face. They are then outfitted with white fairy lights around their body, emulating the “WALK” signal.
It’s a simple concept, but quite accurately replicates a typical crosswalk sign. It’s something we certainly haven’t seen before, which is impressive in this Internet era when anything new is old again mere minutes later.
If your tastes are more avant-garde, though, consider going the TV head route next year. If you’ve built your own high-tech, high-concept costume, hit us up on the tips line!
5 thoughts on “This Crosswalk Sign Costume Is A Halloween Hit
  1. Years ago, my girlfriend stood outside my TV repair shop dressed as … a TV :) I made the TV out of a cardboard box with the screen made from the actual fresnel lens out of a rear projection TV (this was before flat screens) with “static” behind it. Knobs were glued on and she wore rabbit ear antennas on her head.
Leave a Reply to fdufnewsCancel reply
