3D Printer Repurposed For Light-Duty Lab Automation Tasks
Laboratory automation equipment is expensive stuff, to such a degree that small labs are often priced out of the market. That’s a shame, because there are a lot of tedious manual tasks that even modest labs would benefit from automating. Oh well — that’s what grad students are for.
But it actually isn’t that hard to bring a little automation to the lab, if you follow the lead of [Marco], [Chinna], and [Vittorio] and turn a 3D printer into a simple lab robot. That’s what HistoEnder is — a bog-standard Creality Ender 3 with a couple of special modifications that turn it into a tool for automating histology slide preparation. Histology is the study of the anatomy of tissues and uses various fixing and staining techniques to make microscopic features visible. In practice, this means moving baskets of glass slides back and forth between jars of different solutions, a job that’s perfect for a simple Cartesian gantry lab robot with a small work envelope and light loads.
None of the printer modifications are permanent; the 3D printed accessories — a hook for the slide basket and a carrier for standard histology staining jars — can quickly come off the printer to return it to its regular duty. All it takes to run HistoEnder is a bit of custom G-code and some careful alignment of the jar carrier on the print bed. We suppose the bed heater could even be used to warm up the fixing and staining solutions. There’s a brief video of HistoEnder in action embedded in the tweet below.
This isn’t the first time this team has repurposed technology for the lab — remember the fitness band that was turned into an optical densitometer?
Continue reading “3D Printer Repurposed For Light-Duty Lab Automation Tasks” →
Bike-Riding Skeleton Stalks The Streets On Halloween
Stationary pumpkins and motionless skeletons aren’t enough to scare people these days. If you want to really create a fright on Halloween, you need something more convincing. This bike-riding skeleton from [rc jedi] might just do the trick.
A few neat tricks make this impressive build surprisingly simple in nature. Propulsion is via a scrapped electric scooter drivetrain hidden in the sidecar. This not only propels the rig, but the third wheel means there’s no need to do any fancy balancing work to keep the bike upright. Steering is via a big chunky servo mounted to the bike frame which controls the handlebars. Regular RC gear handles remote control of the steering and drive.
The skeleton itself was an off-the-shelf buy, that was modified to have more flexibility in its joints. The hands were attached to the handlebars, and the feet attached to the pedals, so it appears to pedal the bicycle as it moves down the road. A dog skeleton rides along in the sidecar as a spooky companion.
A skeleton prowling the streets by BMX is a wonderfully spooky sight. We’ve seen some other great skeleton builds before, too, from the canine to the musical variety. Video after the break.
Continue reading “Bike-Riding Skeleton Stalks The Streets On Halloween” →
An iPhone sits in a users hand open to the YouTube app. What is unusual is that the iPhone is bent in an L shape and is still functioning properly.
First Folding IPhone Doesn’t Come From Apple
Folding phones are all the rage these days, with many of the major smartphone manufacturer’s having something in this form factor. Apple has been conspicuously absent in this market segment, so [KJMX] decided to take matters into their own hands with the “iPhone V.” (YouTube – Chinese w/subtitles via MacRumors).
Instead of trying to interface an existing folding phone’s screen with the iPhone, these makers delaminated an actual iPhone X screen to use in the mod. It took 37 attempts before they had a screen with layers that properly separated to be both flexible and functional. Several different folding phones were disassembled, and [KJMX] found a Motorola Razr folding mechanism would work best with the iPhone X screen. Unfortunately, since the iPhone screen isn’t designed to fold, it still will fail after a relatively small number of folds.
Other sacrifices were made, like the removal of the Taptic Engine and a smaller battery to fit everything into the desired form factor. The “iPhone V” boasts the worst battery life of any iPhone to date. After nearly a year of work though, [KJMX] can truly claim to have made what Apple hasn’t.
Curious about other hacks to let an iPhone do more than Apple intended? Check out how to add USB-C to an iPhone, try to charge it faster, or give one a big memory upgrade.
Scratch Built Wind Turbine Makes Power And Turns Heads
If you’ve ever aspired to live off the grid, then it’s likely that one of the first things you considered was how to power all of your electrical necessities, and also where to uh… well we’ll stick to the electrical necessities. Depending on your location, you might focus on hydroelectric power, solar power, or even a wind turbine. Or, if you’re [Kris Harbor], all three. In the video below the break, we get to watch [Kris] as he masterfully rebuilds his wind turbine from scratch and reconfigures his charging solution to match.
The Rotors Are Built With a 3d Printed Rotor Jig
A true hacker at heart, [Kris] has used a everything from 3d printing to broken car parts in order to build his new wind turbine. The three phase generator is constructed from scratch.  A hand wound stator is held firmly between two magnetic rotors, where 3d printed jigs hold the magnets in place.
A CNC cut backing plate holds everything together while also supporting the automatically furling vane that keeps the entire turbine from self destructing in inclement weather. A damaged wheel hub from [Kris]’ Land Rover provides the basis for a bearing so that the entire turbine can turn to face the wind, and various machined parts round out the build. The only things we didn’t see in the build were hot glue and zip ties, but we remain hopeful. Continue reading “Scratch Built Wind Turbine Makes Power And Turns Heads” →
Concrete Boat Cements Its Way To High Speeds
Steel is scarce. Wood is not an option. And you need a boat now. These wartime circumstances drove innovation in all kinds of crazy directions, and one somewhat less crazy direction — concrete boats. As [Peter Sripol] demonstrates in the video below the break, making an RC concrete boat isn’t hard. Making a fast one on the other hand is. But that didn’t stop him from trying, and we think the effort deserves a look.
Starting with a basic displacement style hull, [Peter] and his cohorts experimented with a simple RC boat that worked, but could only move at slow speeds. They turned things up a notch or two and instead modeled their concrete boat after an RC speedboat hull that they had on hand.
The construction methods left a lot to be desired though, and they even tried various wire meshes as rebar, but they proved too heavy. Eventually though, they got a working hull, and had some fun with it. Rather than try to make the hull watertight with a rudder and propeller, they opted for a ducted fan and an airboat style rudder to make what they call the “world’s fastest concrete boat”.
Whether it’s the fastest or not is unconfirmed, but it is fast and actually gets on step fairly nicely. We applaud the exploration of alternative materials and the experimentation with different build methods. If building things with concrete floats your boat, then be sure to check out this concrete pinhole camera.
Continue reading “Concrete Boat Cements Its Way To High Speeds” →
Hackaday Podcast 192: Supercon Was Awesome, How To Grind ICs And Make Your Own Telescope
This week, Editor-in-Chief Elliot Williams and Managing Editor Tom Nardi are still flying high on their post-Supercon buzz (and are a bit jet lagged) this week. We’ll start with some of the highlights from our long-awaited Pasadena meetup, and talk a bit about the winner of this year’s Hackaday Prize. Talk will then shift over to shaved down NES chips, radioactive Dungeons and Dragons gameplay, an impressive 3D printed telescope being developed by the community, and the end of the Slingbox. Stick around for a double dose of Dan Maloney, as we go over his twin treatises on dosimetry and the search for extraterrestrial life.
Download it, burn it on a floppy, and you’ll have it forever!
Check out the links below if you want to follow along, and as always, tell us what you think about this episode in the comments!
Continue reading “Hackaday Podcast 192: Supercon Was Awesome, How To Grind ICs And Make Your Own Telescope” →
This Crosswalk Sign Costume Is A Halloween Hit
Halloween costumes can be anything from an expensive authentic recreation of a character’s garb, to a cheap knockoff bought from one of those overcrowded pop-up stores. Alternatively, you can get creative and conceptual about things, such as by building yourself a crosswalk sign costume.
The creation of [jared531], the build uses a large piece of cardboard painted black as the base. This sits behind the wearer, and is given a yellow outline to emulate the crosswalk signals common in the US. Red fairy lights are then laid out on half of the cardboard in a pattern emulating the “STOP” hand signal.
The wearer should then dress in all-black garb, and attach the flat cardboard panel to themselves with elastic straps. A black mesh face covering helps to complete the look by blending in the wearer’s face. They are then outfitted with white fairy lights around their body, emulating the “WALK” signal.
It’s a simple concept, but quite accurately replicates a typical crosswalk sign. It’s something we certainly haven’t seen before, which is impressive in this Internet era when anything new is old again mere minutes later.
If your tastes are more avant-garde, though, consider going the TV head route next year. If you’ve built your own high-tech, high-concept costume, hit us up on the tips line!
