Gaze Upon The Swimming Mechanical Stingray, Made With LEGO
Stingrays have an elegant, undulating swimming motion that can be hypnotic. [Vimal Patel] re-created this harmony with his fantastic mechanical mechanical stingray using LEGO pieces and a LEGO Technics Power Functions motor. The motor is set in a clever arrangement that drives the motion remotely, so that it and electrical elements can stay dry.
The mechanical stingray sits at the end of a sort of rigid umbilical shaft. This shaft connects the moving parts to the electrical elements, which float safely on the surface. This leaves only the stingray itself with its complex linkages free to move in the water, while everything else stays above the waterline.
We’ve seen some impressive LEGO creations before, like this race car simulator and pneumatic engine, and the mechanical action in this stingray is no exception. Interested in making your own? The part list and build directions are available online, and you can see it in action in the video embedded below.
5 thoughts on “Gaze Upon The Swimming Mechanical Stingray, Made With LEGO
  1. Must say that this is very impressive, look and motion pattern is way better then i thought possible given the size and hat it was built with LEGO. Would love to see some better above water video, to better see the construction and motion.
Leave a Reply to JanWCancel reply
