This Week In Security: Scamming The FBI, In The Wild, And AI Security
If you’re part of a government alphabet agency, particularly running a program to share information to fight cybercrime, make sure to properly verify the identity of new members before admission. Oh, and make sure the API is rate-limited so a malicious member can’t scrape the entire user database and sell it on a dark web forum.
Putting snark aside, this is exactly what has happened to the FBI’s InfraGuard program. A clever user applied to the program using a CEO’s name and phone number, and a convincing-looking email address. The program administrators didn’t do much due diligence, and approved the application. Awkward.
BSD Ping
First off, the good folks at FreeBSD have published some errata about the ping problem we talked about last week. First off, note that while ping does elevate to root privileges via setuid, those privileges are dropped before any data handling occurs. And ping on FreeBSD runs inside a Capsicum sandbox, a huge obstacle to system compromise from within ping. And finally, further examination of the bug in a real-world context casts doubt on the idea that Remote Code Execution (RCE) is actually possible due to stack layouts.
If someone messes up somewhere, go look if you messed up in the same or similar way somewhere else.
Sage advice from [Florian Obser], OpenBSD developer. So seeing the ping problem in FreeBSD, he set about checking the OpenBSD ping implementation for identical or similar problems. The vulnerable code isn’t shared between the versions, so he reached for afl++, a fuzzing tool with an impressive list of finds. Connect afl++ to the function in ping that handles incoming data, and see what shakes out. The conclusion? No crashes found in this particular effort, but several hangs were identified and fixed. And that is a win.
Citrix In The Wild
A vulnerability in the Citrix ADC (Application Delivery Controller), a load balancer for complex web applications, is being actively exploited. This one prompted the NSA to issue a PDF advisory, laying blame for the attacks at the feet of APT5, thought to be an Iranian actor.
The actual vulnerability is an old one, apparently quietly fixed a couple years ago. It has just now been discovered to be a serious problem, allowing a vulnerable device configured to do SAML authentication to be remotely compromised. Patches have now been made available for multiple vulnerable versions, and Indicators of Compromise (IoCs) have been published.
SPNEGO NEGOEX
That section header has strong Sneakers vibes, and my eyes keep trying to rearrange those letters into “Too Many Secrets”, but it just doesn’t fit. The “NEGOEX” refers to EXtended NEGOtation. “SPNEGO” is an acronym for “Simple and Protected GSSAPI Negotiation Mechanism”. And of course, GSSAPI is the “Generic Security Service Application Program Interface”. All that alphabet soup eventually boils down to a method to negotiate authentication protocols. The important bit is that by design, this protocol runs before any authentication takes place, and it’s accessible in a bunch of different services. SMB, RDP, SMTP, and even HTTP can expose SPNEGO negotiation. And of course, there was a critical security vulnerability in Microsoft’s implementation.
The vulnerability, CVE-2022-37958, was patched back in September, and classified as high severity. Just a couple days ago, [Valentina Palmiotti] demonstrated that the vulnerability could be used for Remote Execution, and It’s been bumped to critical severity. The full details will release in 2023, giving everyone plenty of time to get this one patched. Based on what’s been released so far, that’s going to be pretty important. The race is now on, to see whether any malicious groups figure out the details before then.
FortiOS RCE
And rounding out the hair-on-fire section of the news, a pre-auth RCE in FortiOS is being actively exploited to compromise Fortinet devices. The update has been out for a month, but wasn’t marked as a security fix, so rollout has been a bit slow. It’s a buffer overflow in the SSL-VPN service, and appears to exist all the way back to the 5.x release series. As the older 5.x and 6.0.x firmwares are beyond support, so may not receive updates fixing this one. Disabling the Internet-facing VPN appears to be a valid workaround to the issue.
AI “Improves” Security
The new hotness in machine learning is OpenAI’s chat bot, which has been full of surprises. [Rick Osgood] does Red Team penetration testing, and just had to try out using the tool for simulated evil. He asked it to generate a phishing email, promising a gift card for filling out a survey. And the results were depressingly good. So good in fact, that [Osgood] had to tell the AI to make the email seem just a little shady, with hilarious results.
SVG Smuggling
Scalable Vector Graphics (SVG) is bit of an odd duck. It’s an image format, particularly useful because the resulting images are infinitely scalable. It’s also a markup language based on XML, and all sorts of interesting bits of data can be included. That apparently includes HTML and JavaScript code, and that code can be Base64 encoded. And this makes for a useful way to sneak malicious code past a security solution. For even more creative mayhem, once the JavaScript code starts running, it can even be used to build an executable file in memory, and download it to the local machine. Sneaky.
16 thoughts on “This Week In Security: Scamming The FBI, In The Wild, And AI Security
  1. As a long time member of InfraGard, I was very intrigued by this hack, and can confirm everything that Brian found out. THis is one of those things where you would never think of that as an attack vector, but I am sure that this opened up a lot of people’s eyes.
  2. That SVG hack: I shake my head. Like, I get making file formats flexible, but allowing JavaScript in an image format just seems like a terrible idea. It’s like they saw macros in office documents, and thought “hey, let’s have all of those problems too!”
    1. Security software should just pick up on the malicious code, wherever it’s been embedded. GIFs and JPEGs can be constructed to cause buffer overflows and write code in memory that can be executed. Doesn’t mean a viewer or webbrowser shouldn’t be sandboxed. If a system is exposed to user input, all input should be treated as unsafe.
      1. It’s a “side effect” of using XML. SVG is just a set of elements and attributes in an otherwise generic XML document.
        Fortunately, filtering out unsafe elements and attributes is not hard.
        Unfortunately, SVG uses it’s reliance on XML to support metadata, inter-document linking and other useful things. This means the definition of elements/attributes is spread across several standards.
        (In SVG’s defense, to be its own, self-contained format would require defining and implementing the metadata, etc fields, much like GIF, JPEG, MPEG and others. Being XML-based, the SVG specification is free to focus on vector graphics.)
      2. A side effect of using XML. SVG is just a set of elements and attributes in otherwise generic XML documents.
        Fortunately, filtering unsafe elements/attribute is easy. Unfortunately, SVG relies on other XML-based specifications for metadata, inter-document links and other useful things, so the definition of “safe” elements/attributes is spread across several specifications.
        Over filtering is very likely to occur
      1. Inkscape itself doesn’t inject Javascript or HTML, but there are extensions that do,like animating images. Also, one I used to use, JessyInk, which uses layers to make PPT-like slideshows.
        Looks like these extensions will soon not be usable as SVG viewers start filtering out unsafe elements and attributes (and likely over filtering)
Leave a Reply to snapcracklinsCancel reply
