The $50 Pen Plotter
[Arca] sets out to build himself a low-cost pen plotter that doesn’t require access to a 3D printer. The plotter uses a coreXY arrangement, powered by 28BYJ-48 stepper motors, which he overdrives with +12 VDC to increase the torque. Pen up and down control is done using a stepper motor salvaged from a DVD reader. The frame is constructed using PVC electrical conduit and associated fittings, and [Arca] uses the hot glue gun quite liberally. Steppers were driven by A4988 modules with heatsinks, and motion control is provided by GRBL running on an Arduino UNO.
He has a few issues with glitches on the limit switches, and is continuing to tweak the design. There is no documentation yet, but you can discern the construction easily from the video if you want to try your hand at making one of these. This is a really cool DIY plotter, and many parts you probably have laying around your parts boxes. As [Arca] says, it’s not an AxiDraw, but the results are respectable. Keep a lookout for part 2 of this project on his YouTube channel.
23 thoughts on “The $50 Pen Plotter
  1. Great work for a very low cost plotter!
    I have a zero cost suggestion that should improve its performance a little, depending on what you’re trying to draw: rearrange the pulleys to keep the belts parallel to the guide rails. That way, belt tension won’t vary as the pen carriage moves and precision and accuracy will improve.
  2. Low pass rc filter on the limit switches, i added them to my CNC, with a grbl uno. Issues before, none after. 1k 3uF if I recall
  3. I’m wondering if thin wall metal electrical conduit, EMT in North America, would be worth considering? Seems like it would be more rigid but corner joints maybe less so.
    1. Good idea. Maybe run a long bolt through both conduits at the corners to act as gussets. Not an easy set of holes to drill, depending on your equipment, but not impossible. If you want to get fancy, you could cut notches and make wide, rectangular washers to distribute the load better.
  4. A good frame material for this would,be celulose lignin laminate,comes in many sizes,and is easily shapable and joined into assemblies
  5. Electrical conduit isn’t white and doesn’t have sharp 90s. Looks like plumbing PVC pipe.
    EMT conduit would be better. Only a few cents more. However you would need to bend the EMT.
    1. You’re right about the hard 90 degree bends though – would be hard to get a fish wire through those, but I think they are available.
      Anyways – I love the idea of using electrical conduit for the frame of the plotter!
    2. Here in Australia, electrical conduit is supposed to be orange. To help distinguish it when you go digging.
      Irrigation and drainage (rain water) are white, and a purple pipe carries recycled water – great for gardens but not suited for drinking.
    1. Ikea is a fairly cheap source of stainless-steel tubing which happens to be open on a Sunday.
      They call it Grundtal and it comes in 600mm lengths in a pack of 6 for £12. It has handy threaded (axial) holes in the end too.
      I once mis-assembled a Grundtal shelf into a TV wall mount.
Leave a Reply to Andy PughCancel reply
