Outdated HP Microserver Gets A New Brain
An open top of a black PC case. Inside we can see an aluminum extruded mini PC case inside the 5" optical drive bay. A Samsung SSD sits along the back wall of the case and a flash drive sits between the front of the 3D printed "drive" and the actual mini PC.
What to do if you have a really cool old HP MicroServer that just can’t keep up with the demands of today? [jacksonliam] decided to restomod it by installing a mini PC into the drive bay.
The HP N54L MicroServer was still running, but its soldered CPU and non-standard motherboard made a simple upgrade impossible. Evaluating the different options, [jacksonliam] decided to save the case and PSU by transplanting an Intel Alder Lake mini PC into the drive bay with 3D printed brackets and heat set inserts.
Selecting a fanless “router” model to increase reliability, he was able to find an M.2 to mini-SAS adapter to attach the four drive cage to the NVME slot on the new PC. Power is supplied via the 12 V line on the ATX power supply and one of the mini PC’s Ethernet lines was broken out to a 3D printed PCI slot cover.
Looking for more ways to rejuvenate an old computer? How about putting a Mac mini inside an old iMac or a Raspberry Pi inside an Apple ][?
7 thoughts on “Outdated HP Microserver Gets A New Brain
  1. I always thought it would be cool to turn an old tower server into a something like a blade server by stuffing SBCs or mini-PCs into the plentiful drive bays…it would be even cooler to adapt the case to take a standard mainboard at the same time though ;-)
    1. These mini PCs have 4×2.5Gbe so I guess with 4 of them you could make a fully connected mesh network for the backplane without needing a switch.
      Though as good as the N100 is for a low power server, I’m not sure 4xN100 CPUs each with a max of 32GB single channel RAM each would be worth it over just having a more traditional threadripper workstation.
  2. Thanks for posting, I’ve always wanted a project to make hackaday front page!
    It’d be great to hear if anyone replicates this.
    1. Great idea. I wish I’d seen this 6 months ago – I ended up getting a gen8 Microserver as an upgrade. However, now I know there are M2-MiniSAS, I might look at fitting a mini itx board in one.
  3. Funny thing is what those run on E-bay. Might try that in the future with mine even though it does NAS duty just fine.
  4. That’s certainly one option. Although very curious as to whether a standard ITX board would have some advantages. especially if Bifurcation was on the table.
  5. Why didn’t you just put the mini PC at the bottom in place of the original mainboard? That seems to fit very well…
