3D Printing In Custom PLA With A TPU Core
[Stefan] from CNC Kitchen explored an unusual approach to a multi-material print by making custom PLA filament with a TPU core to make it super-tough. TPU is a flexible filament whereas PLA is hard almost to the point of being brittle. The combo results in a filament with some unusual properties, inviting some thoughts about what else is possible.
Cross-section of 3D print using white PLA with a red TPU core.
[Stefan]’s video covers a few different filament experiments, but if you’d like to see the TPU-PLA composite you can skip ahead to 18:15. He first creates the composite filament by printing an oversized version on a 3D printer, then re-forming it by running it through a Recreator to resize it down to 1.75 mm.
We have seen this technique of printing custom filaments before, which is useful to create DIY multi-color filaments in small quantities right on a 3D printer’s print bed with no special equipment required. This is an effective method but results in filament with a hexagonal profile, which works but isn’t really ideal. By printing his custom composite at 4 mm diameter then resizing the filament down to 1.75 mm, [Stefan] was able to improve overall printability.
That being said, TPU and PLA have very different characteristics and don’t like to adhere to one another so the process was pretty fiddly. TPU-cored PLA might be troublesome and uncooperative to make, but it can be done with some patience and fairly simple equipment.
Despite the difficulties, test prints were pretty interesting. PLA toughness was roughly doubled and under magnification one can see a lattice of TPU strands throughout the prints which are unlike anything else. Check it out in the video, embedded below.
11 thoughts on “3D Printing In Custom PLA With A TPU Core
  1. The test used is called Charpy impact test https://en.wikipedia.org/wiki/Charpy_impact_test
    And I’m not sure whether it’s result are very representative in this case. My first guess is that the PLA breaks first before the TPU starts elongating and absorbing energy. If you print a product, the PLA breaks, but the TPU still holds the pieces together, is your product then broken or not?
    It probably depends on the product, but the Idea is at least interesting.
  2. What about filling the channel with something that can leave empty space after pulling, i.e. water-soluble filament, or compressed air, water or oil? One could make thin pipes in which water could circulate to make i.e. self-cooling clothes. Or, if one makes a core of transparent plastic, it could be fibre optics.
  3. Seems like it should be reversed, no? TPU lattice and PLA cores?
    like steel rebar embedded in concrete, except it seems to be the reverse, i.e., concrete cores embedded in steel lattice.
    But PLA and TPU are probably more similar in flexibility/elongation than are steel and concrete.
  4. Just use sunscreen PLA-ST – super tough.
    It prints easily, it makes really strong prints one wall thickness. Really strong.
    As some who’s been wearing thr issues but been still printing with ABS or PETG, the PLA-ST literally shits on everything else I have ever tried.
    I printed out an airless tennis ball, and at 100kg I can stand on it without even a hint of deforming, let alone crushing.
    If you are in any way disappointed with your current filament, try this one, I’ll bet one of the children that you will be amazed.
    Main disadvantage is only available in black and in white.
    1. Was it Samsung that wrote “literally shits on” ? Please don’t use “literally” like this. I’m interested in this PLA-ST, but you’re not helping convince me by claiming that literally excrete faeces on everything.
      “PLA-ST shits on the competition” is fine. Claiming that it literally shits on anything is just silly. This isn’t reddit, you don’t need to talk that way.
Leave a Reply to MechEngCancel reply
