This Tiny Game Boy Lets The Real Thing Play Online
Back in 2021, [stacksmashing] found that it took little more than a Raspberry Pi Pico and some level-shifters to create a USB connection with the Game Boy’s link port. Add in the proper software, and suddenly you’ve got online multiplayer for the classic handheld. The hardware was cheap, the software open source, and a good time was had by all.
Inspired by both the original project and some of the hardware variations that have popped up over the years, [weiman] recently set out to create a new version of the USB link adapter that fits inside a miniature 3D printed Game Boy.
The big change from the original design is that this is using the far smaller, but equally capable, RP2040-Zero development board. This is mated with a SparkFun logic level converter board (or a clone of one from AliExpress) by way of a custom PCB that also includes the necessary edge connectors to connect directly to a Game Boy Link Cable.
Once the PCB is assembled, it’s dropped into the 3D printed Game Boy shell. [weiman] really worked some nice details into the case, such as aligning the d-pad and buttons in such a way that pressing them engages either the RESET or BOOTSEL buttons on RP2040-Zero. The screen of the printed handheld also lines up with the RGB LED on the top of the dev board, which can produce some cool lighting effects.
The original project from [stacksmashing] was an excellent example of the capabilities of the Pi Pico, and we’re glad to see it’s still being worked on and remixed by others. Even though the state of Game Boy emulation is nearly perfect these days, there’s still something to be said for working with the original hardware like this.
5 thoughts on “This Tiny Game Boy Lets The Real Thing Play Online
  1. Pfft stacksmashing
    You can just use an esp32 as a forced host to the Gameboy
    That way you can drive the serial port at a faster speed
    Even for the dmg 64-128khz is wayy better than just 8khz serial clock
    Now you can implement a wifi serial modem and Bluetooth serial stack
    Just get a ROM hack for networking multiplayer or a homebrew app
    Can even run a bbs server with a dmg, add 512k of sram and some ROM on a cartridge with cpld
    1. Great that the Gameboy and esp uart both operate at ttl levels, just stripped down rs232 with out negative rails and an ass of handshakes wires
      Just rx, tx, clk are actually needed you can handshake in software
Leave a Reply to weimanCancel reply
