If you’d like to measure the speed of your cycling then it’s easy enough to buy a cycle computer, but as [Clovis Fritzen] has done it’s also an option to build one. The result of his work is a smart PCB on which the speed is indicated with a row of LEDs.
The sensor is a straightforward affair, a reed switch with a magnet on a wheel, which is sensed by an ESP8266. The six LEDs are charlieplexeed over three lines. To keep the supply voltage correct for the ESP from the uncertain state of a lithium battery, a small buck-boost module is used. Sadly the code doesn’t seem to make the speed available via the wireless part of the processor, but we’re guessing that a bit of extra software work could fix that.
The result when put in a box on the handlebars, is a smart but simple instrument that would aid any bike. It’s by no means the first one we’ve brought you and we doubt it will be the last.
Build your own bicycle odometer, practical and not too difficult to start with, great idea :-)
Thanks [Clovis]!
Is the speed displayed in binary?
The speed is not binary, each of the 6 LEDs are lit individually with 5km/h speed increases
It’s a speedometer (distance/time) not an odometer (distance).
