Ever want your project equipped with a cellular interface for a data uplink? Hop in, I have been hacking on this for a fair bit! As you might remember, I’m building a router, I told you about how I picked its CPU board, and learned some lessons from me daily-driving it as a for a bit – that prototype has let me learn about the kind of extra hardware this router needs.
Here, let’s talk about LTE modems for high data throughput, finding antennas to make it all work, and give you a few tips that should generally help out. I’d like to outline a path that increases your chances of finding a modem working for you wonderfully – the devices that we build, should be reliable.
Narrowing It Down
If you look at the LTE modem selection, you might be a little overwhelmed: Simcom, Qualcomm, uBlox, Sierra, Telit, and a good few other manufacturers package baseband chipsets into modules and adjust the chipset-maker-provided firmware. The modems will be available in many different packages, too, many of them solderable, and usually, they will be available on mPCIe cards too. If you want to get a modem for data connections for a project, I argue that you should go for mPCIe cards first, and here’s why.
Using a module makes sense if you’re making something really tiny – and even then, you should test with a mPCIe card in the first revision, which is why modem manufacturers usually have them available in the first place: mPCIe cards are testing platforms. A lot of mPCIe modules are also available cheaply, since they’re also used in laptops, so the second-hand market in your country is going to have some mPCIe cards you can try out, and so will eBay.
Then, there’s the interface question. You might have looked into embedded modem datasheets already. Often, you will see a UART interface, maybe SPI or even SDIO, and, invariably, USB. If you are doing low-throughput data, UART or anything else might just do wonderfully. For “building an LTE uplink router” purpose, the easiest interface to use is USB, and the reason is multi-fold. It’s the most popular path, so you will find more modem options, more documentation, more open-source support, and encounter fewer problems along the way.
If you’re using a M.2 modem, you might even find a USB3 option, in case you want your uplink to be seriously high-speed! In this prototype, I’m using a mPCIe breakout, and for testing out M.2 router cards, I am using a mPCIe to M.2 adapter.
All done? Nope. You do need testing, however, because you can’t just pick any modem. You might have to try one, two, or three different modems before you settle on a workable option, and the reason is simple.
Some Tailoring Required
Specifically, configuration interfaces are where things start to break. Older software modems use a virtual serial port over USB for both data and configuration. In slightly more recent times, you would get a combination of a virtual Ethernet card for data and a serial port for AT command configuration.
AT commands have gotten old, however, so interfaces like QMI have taken hold, and now you better use it, even though AT commands are the traditional way. QMI configuration is often needed for the new and relatively less explored interfaces. Sometimes a feature is broken when configured through UART, but works over QMI. Sometimes the UART connection bringup process is just not as well documented. It makes sense – at some point, we need to shed the cruft of the Hayes command set, so don’t get too comfortable. Firmware loading tools are another gotcha. With some old modems, like the Gobi cards, you need a loader script and a matching firmware to go with it. Be prepared to try out a firmware image or two before the modem works the way you need it to. And be prepared to hit dead ends.
This means that you will want to have a setup where you can try out a few different modems if needed. Thankfully, you have a mPCIe socket like I suggested, right? Again, it’s just USB and an amp at 3.3 V; you don’t even need any GPIOs to spare. Some modems even support direct power from a single-cell LiIon battery. This is explicitly stated in the M.2 standard, so if you opt for a M.2 B-key slot, you might be able to skip on a voltage conversion step.
Getting Antennas Quickly
Switching between M.2 and mPCIe can be done with a simple adapter. But beware – they will also use different antenna connectors, with mPCIe modems using uFL connectors and M.2 modems using wFL. So let’s talk about antennas.
You shouldn’t connect a modem to a network without an antenna attached. Chances are, your modem has antenna detection circuitry built-in, but there’s always the rare modem that will try to transmit out of an empty antenna socket and gets its signal reflected back into itself, possibly damaging its transmitter circuits. So, you have a mPCIe modem and it needs antennas that can work at LTE frequencies – how to proceed?
The simplest answer is to get some laptop WWAN antennas out of old laptops, or buy a set of replacement laptop WWAN antennas. These are the easiest two ways to find an antenna with a uFL connector that works for LTE. Don’t use WiFi antennas – they’re tuned for 2.4 GHz in a way that will likely make them useless for WWAN. The antennas that I currently use have been taken out of a Thinkpad that didn’t even have a WWAN card inside. These antennas tend to be designed to work from within the laptop chassis, sure, but they should be good enough outside of it. One nuance – they will have long cables, so you will want to shorten them to your liking or tuck them away somewhere.
Don’t have laptop antennas? Aliexpress will deliver, but you have to be careful there, as not all antennas sold as “LTE” are actually capable of working at these frequencies, mis-labelling and shoddy tuning is commonplace when it comes to hobbyists, because we often don’t really check. If you don’t have something like a NanoVNA, you will want to at least do some simple tests – buy a few antennas, swap them in one by one, remembering to power the modem down, and check the RSSI and the data rates. Otherwise, you can get antennas from specialty shops, but be prepared to pay a bit extra and maybe need some uFL to SMA adapters.
As long as you get the proper antennas and distinguish between wFL and uFL connectors when getting them, you should be in the clear, and that’s about all you need to have an LTE modem module used in your project.
Debug Interface For a Rainy Day
Here’s the last part to mind – you will want to make your initial prototypes flexible for debugging, especially for OpenWRT, which doesn’t have much of an onboard debugging toolkit. For instance, if you have a USB connection in your system, make it tappable so that you can plug a USB cable and have the modem be rerouted to an external device. A single USB2 2:1 mux and a USB-C connector should do wonders – two pairs of zero ohm jumpers are tempting but note that they increase the iteration time a lot when debugging.
Modems are tested on particular OSes, mostly Windows in practice, so when you’re facing a problem, you really want to be able to figure out if this a problem in your drivers, in your power supply, or in your modem’s firmware. How will you update your modem’s firmware for testing purposes, will you have to port a firmware update tool to OpenWRT, or will it be as simple as plugging a cable into a different computer? If your link is dropping out, can you easily check whether that happens if you use a full-fledged Linux computer with an Ubuntu install, or a Windows VM? These are good reasons to have a separate USB line.
So to sum up: use a socket like M.2 or mPCIe so that you can test modem compatibility and stability. Modems are black boxes with closed firmware, and you have to make sure you don’t lock yourself into a glitchy one by having designed a board for a bespoke footprint LGA or QFN-like module. When getting antennas, laptop antennas are an easy shortcut; otherwise, get a few different antennas and do some range tests. And finally, make your USB connection tappable because it helps for debugging.
The modem I went is the EC25 mPCIe card – it’s a card that was put into a lot of laptops, and it even has a GPS antenna hookup point, which is nice to have. Funnily enough, it appears to be at least somewhat compatible with the open firmware that the PinePhone EG25 modem has – we might talk about that in imminent future. Next time, I’d like to talk about OpenWRT and all the ways you can hack on it – it’s a wonderful Linux distribution, but it’s different from the others, and I hope that showing my workflow can help you!
I find the biggest hassles are getting a SIM card with good rate from a provider that allows data-only devices and then to ensure that the cellular network accepts the data-only device IMEI (Verizon being particularly difficult, AT&T possibly too).
The final frontier at the moment seems to also be eSIM hardware and software support…
If you are in the US, i have been using data only sims from embeddedworks on my RPI projects with good success. Speeds are a bit faster than what they are supposed to be capped at as well.
Don’t even bother with Charter (ie. Spectrum Mobile). Those nitwits refuse to provision any device not on their white list of IMEI’s that are known to them. In other words, you purchase the phone from them, or we won’t allow you on “our” network – oh, by the way, they’re paid squatters on Verizon’s network (Spectrum is an MVNO using Verizon’s infrastructure), so it’s not really their’s anyway.
FCC complaints were a waste of time.
Spectrum’s “regulatory affairs VP” dug their heels in said basically “F U”.
So currently investigating class action lawsuit against them (won’t be their first).
Evidently they never learn – company “leadership” team needs to be replaced.
This will cost them.
BYOD doesn’t actually apply even though they market the concept.
I tried this a couple of years ago with, IIRC, a Quectel HAT on a Pi Zero and an AT&T sim from a prepaid phone and, although my testing was very brief, it seemed to connect. Verizon wouldn’t.
Well there’s a number of options, generally either prepaid or pay as you go, from mnvo’s. A few iot options exist, but those are generally slower, e.g. 64kbit. Something called roamless is apparently $3.25/GB and works with both att and t-mobile in the usa at the same time, without speed limits as long as you keep paying. I’ve not heard the best things about mobileX but I think they have cheap verizon slow-throttle and pay as you go options. T-mobile used to offer a $5/mo data-only sim with 500MB full speed and unlimited 128kbit after that, but now their cheapest one is $10 instead. There’s Good2Go mobile if you’d like the same $5 deal on either t-mobile or att, but apparently they can’t afford customer service. Tello is better, but no unlimited throttle.
If your project needs a very fast uplink, and you’re not using it for a very small portion of each month to compensate, then you may find the price structures that work best are the ones intended for either someone’s home internet, or the data-only “smartwatch” addon to a fancier cell plan. There’s a middle level around $25 where you may find a 1-1.5mbps throttle if that’s enough, or you can play your luck and see if Cricket, Metro, or Visible will let their $25 fully unlimited (but deprioritized) plans be used in a non-phone.
A PCIe interface may be the answer if the system you’re using you LTE modem in uses an SBC or MCU that includes that interface, but it’s absolutely not the right answer if you’re using in an IoT or other small microcontroller based system. So yeah, if you want to use LTE on your home router, and want a decent amount of bandwidth, sure, mPCIe is probably your best bet. Same goes for USB: Linux-based micros, sure. Bare-metal MCUs, not so much. I’ve worked with the SIMcom SIM7600g-h, which can do mPCIe, USB, or serial ports, and having both USB 2 and UART ports is perfect for development, because you can either plug the USB into a Linux computer or with USB host capability, or wire the individual serial ports to those on a microcontroller dev board, and there’s very little difference between the two. The modem itself uses separate serial ports for commands (in Hayes-like AT strings) and data (as a PPP device), and the USB device is implemented as multiple serial devices, that do exactly the same thing.
Waveshare makes multiple dev boards for the SIM7600g-h (note that the ‘g’ means global network support, while the ‘h’ means category IV bandwidth), including one that can piggyback on a Pi Zero board, which is the one I’m using. If you do connect it to a Pi Zero, the serial ports are accessed through pogo pins to its microUSB connector, but the Waveshare board also has pinouts for the UART serial ports as well as mic input and speaker output, so you can wire it easily to any microcontroller. This isn’t just a modem; it can be used as a modem or as a voice and SMS phone, and also includes a GNSS receiver for all of the satellite navigation systems, so although not at all a drop-in replacement, it does take over where the 3G SIM800 series left off.
I’ve also been using those SIM7600g modules and find them to be pretty good.
I have a PinePhone (or two) and when it came to a backup LTE for my security system I went with the EG25-G on USB to slip into my OpenWRT box, same as the PINE64 devices.
It’s almost OSS thanks to the efforts of biktorgj and others. The FCC certified parts can’t really be played with unless you want suits to arrive and ask about dodgy packets on the cell towers.
Very happy with the throughput and Linux support.
